fuel screw
Old Dec 2, 2012 | 02:13 PM
1989f250IDI's Avatar
1989f250IDI
fuel screw
i have my 5/32 Allen in there and the fuel screw seems to be stuck. Has anyone ever broke it??
Old Dec 2, 2012 | 03:05 PM
1989f250IDI
The truck died after one mile and won't start now. Please help me
Old Dec 2, 2012 | 04:05 PM
kobaltblue's Avatar
kobaltblue
If it was not turning it most likely already turned up, It will take a little pressure to turn it but If you force it you will bust it and ruin the pump.
Old Dec 2, 2012 | 04:10 PM
1989f250IDI
I was able to make it turn.. But now Im broke down because the truck died
Old Dec 2, 2012 | 04:13 PM
kobaltblue's Avatar
kobaltblue
You may have turned it too far the wrong direction...to the front up..to the rear is down,Or your lift pump died.
Old Dec 2, 2012 | 04:16 PM
1989f250IDI
I turned it clockwise. I pulled the Allen wrench from the back to the front. Is this right?
Old Dec 2, 2012 | 04:19 PM
kobaltblue's Avatar
kobaltblue
Yep you went up,Bad to do it on a N/A.
Old Dec 2, 2012 | 05:16 PM
1989f250IDI
Do what? I went up?
Old Dec 2, 2012 | 06:00 PM
turtlemann14's Avatar
turtlemann14
n/a doesn't need too much more fuel, i'd put it back where you found it and see if it runs again.
Old Dec 2, 2012 | 06:05 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
you do have a egt gauge right?
Old Dec 2, 2012 | 06:07 PM
1989f250IDI
No i was going to install it. But Im aware what they are and i wasn't lugging it or driving it hard at all. And what's wierd is she died while at an idle like it sucked air but my valve on the filter head doesn't shoot any bubbles
Old Dec 2, 2012 | 06:53 PM
91dirtydiesel's Avatar
91dirtydiesel
I've cracked a return line cap will working in engine compartment...causes air intrusion. You have fuel at injectors?
Old Dec 2, 2012 | 09:34 PM
1989f250IDI
All fixed! i had to play with the return line dirty diesel
Chris Skoglun
46
Mar 30, 2017 01:31 PM
racin
1997 - 2003 F150
Apr 5, 2016 07:10 PM
ctaylor57 f100
63
Sep 18, 2011 09:14 AM
tabascom16
Aug 24, 2009 08:43 PM
pasajae1987
Feb 24, 2007 12:00 PM
