I have a 04 f150 and the rear rotors are seized on and is their anyone on here that knows how to get them off WITHOUT destroying the rotors i need to work on the e brakes.
did you take the little rubber plug out of the inside of the wheel hub and back off the e-brake. When I changed my rotors they wouldn't budge an inch until I really loosened that e-brake. You gotta turn the that little star wheel nut(don't remember which way) to loosen it. You can turn it with a long screwdriver.
Yea i did that also,i don't remember what way i turned it,up i think! It seems to be seized onto the axle shaft and i'm afraid that i'm going to break the rotor itself. So thats where i'm at.
