would you buy?
Old Dec 2, 2012 | 08:06 AM
timmyboy76's Avatar
timmyboy76
would you buy?
7.3 Powerstroke Turbo Diesel Motor
Old Dec 2, 2012 | 08:38 AM
joeyd61's Avatar
joeyd61
personally.no...all the goodies are gone so no cores, block is cracked and leaking..
I guess if you have a block and need heads,crank,rods(forged?)then maybe
Old Dec 2, 2012 | 08:41 AM
Kamstutz's Avatar
Kamstutz
It all depends what you want to do with this engine. It is stripped and the block is cracked leaking coolant. When I purchased my truck with a cracked block, I went looking for a replacement. Everything that had Powerstoke name attached to it was a fortune. I went looking for a Navistar block and then people asked why would you want this for? Cause from 97 up it's the same block and doesn't have the Powerstroke $$$ atached to it. There are alot of old school bus engines out there that are alot cheaper than a Powerstroke if you need a block. The only differences for the Powerstroke block is the fuel pump hole in the V of the engine is plugged and #8 cylinder hole is honed a little larger because it runs hotter than a bus engine. I'm a firm believer that once a block is cracked it will always be a problem, unless you what it for a puller and fill all the coolant cavities. My .02
Old Dec 2, 2012 | 09:02 AM
fordpride's Avatar
fordpride
Wouldn't but it. I can get good long blocks here for 6-800
Old Dec 2, 2012 | 09:46 AM
SkySkiJason's Avatar
SkySkiJason
What they said ^^^^.
<1000lbs of scrap metal pictured... We are getting about $0.09/lb here. If ya needed heads it might be worth a couple $100. Most likely its a PMR motor, otherwise the rods are worth a couple $100.
If they are including the injectors, HPOP, turbo, etc - everything that made it 'run like a perfect 10' (Lol) - that's a fair deal. Its a deceptive ad IMHO.
Of course, it is in the land of Fruits and Nuts!!!
Old Dec 2, 2012 | 09:58 AM
SkySkiJason
$1500 OBO includes CAC, radiator AND a trans!!
7.3 INTL Powerstroke engine/ Autotrans
Another for $1500 complete:
7.3 Powerstroke Diesel LOW MILES
Btw, I want the dual AC from this one. Can you say 'on-board air'?? (compressed air that is...)
This is the typical price I see for 'complete' engines here in the southeast...
The problem I have with this price, is that's about what parts and machine shop costs are to rebuild a good longblock. It seems silly to spend that much on an 'old' engine when you could rebuild yours and have a FRESH mill for similar $$$. As long as ya don't have a windowed block (or car accident ) - build what ya got!!!
Fwiw, all PSD blocks are the same from '94-'03.
Old Dec 2, 2012 | 10:32 AM
Kamstutz's Avatar
Kamstutz
94-96 blocks do not have the reinforced push rod cavity webs where as the 97-03 blocks have the reinforced push rod cavity webs.
Old Dec 2, 2012 | 12:11 PM
SkySkiJason
Never heard that, I gotta go look at one of my blocks and see what that means... Is this a deal-breaker for a 'stockish' engine build?
I guess I shoulda said any '94-'03 would work.
Old Dec 2, 2012 | 12:38 PM
BigAlsPSD's Avatar
BigAlsPSD
Yes that is correct, although I am not sure if you weren't going huge HP whether it would make a tremendous difference. Here's pics of a 96 then the second and third are later SD blocks.
Old Dec 2, 2012 | 02:11 PM
Franko72's Avatar
Franko72
Molon Labe
I'm selling my 99 7.3 for $500 sans injectors and turbo.
Not one call ... Yet I see em on cl all the time Here for around a grand.
Old Dec 2, 2012 | 02:16 PM
SkySkiJason
Priced to low. Ask $998.
77fordguy
General Automotive Discussion
17
Aug 3, 2005 11:04 PM
t_dickie
Dec 14, 2004 02:27 PM
Skyking
Aug 4, 2002 11:38 PM
