fuel issues...
Old Dec 3, 2012 | 03:01 PM
vfelix702's Avatar
vfelix702
Do you have 12volts at the fss ontop of the ip with the key in the on position?
Old Dec 3, 2012 | 03:04 PM
86f350's Avatar
86f350
Schrader is back in and I'm cranking more. I'm getting a little fuel at the valve after cranking now but nothing still at the injectors
Old Dec 3, 2012 | 03:07 PM
86f350's Avatar
86f350
Ok don't shoot the idiot lol. I have fuel to the injectors now. My ******* was cranking from the fender mounted solenoid with the key off lmao. Turned the key on and now I'm getting fuel to the injectors just need to bleed her more
Old Dec 3, 2012 | 03:23 PM
vfelix702's Avatar
vfelix702
Ha sweet!!!!!! I was about to run out of ideas.... lol I had assumed you had the key on the whole time lol
Old Dec 3, 2012 | 03:26 PM
86f350's Avatar
86f350
Lol it happens I guess, she's running now but like crap of course
Old Dec 3, 2012 | 03:32 PM
vfelix702's Avatar
vfelix702
Well once you tighten everything up it should smooth out
Old Dec 3, 2012 | 04:15 PM
86f350's Avatar
86f350
truck started, ran for a bit (like crap) tightened all the lines back up then she ran a little longer feathering the throttle then she fell on her face. I pulled the fuel filter and she was half empty...
Old Dec 3, 2012 | 04:37 PM
vfelix702's Avatar
vfelix702
Ok try taking the hose off fuel pump inlet side and put it in a 5 gall of diesel use the gas can as fuel supply and see if your probel goes away and the fuel filter stays full .... if so then a prob lies with the tank and fsv and such
Old Dec 3, 2012 | 04:41 PM
86f350's Avatar
86f350
Thats kinda what I was thinking too Vic. Thx, Ill get on that tomorrow and report back. Thanks for all your help so far man.
Old Dec 3, 2012 | 04:54 PM
vfelix702's Avatar
vfelix702
Hey no probs glad to help
Old Dec 6, 2012 | 04:01 PM
86f350's Avatar
86f350
Vic, truck is running for now off of a can of diesel so I have to check in on from back beyond the lift pump. Is there a way to deleted the FSV since I wont be using the rear tank for now ?
Old Dec 6, 2012 | 04:23 PM
vfelix702's Avatar
vfelix702
Well thats good to hear!!! Whats keeping you from running your dual tanks?
Old Dec 6, 2012 | 04:25 PM
  #28
86f350's Avatar
86f350
Rear tank leaks so I blocked off the rusted fuel lines for the rear tank
Old Dec 6, 2012 | 04:41 PM
  #29
vfelix702's Avatar
vfelix702
At the front tank sending unit there should be a supply and return hose... take those off the sender neck and run a new supply line from the sender (out to the inlet of the mechanical full pump. And the other line to the (return) tee from sender to the tee that the diesel fuel returns to from each bank.... does that make sense?
Old Dec 6, 2012 | 04:48 PM
  #30
vfelix702's Avatar
vfelix702
Have you checked the fuse panel for a blown or weak fuse? Causeing the fsv not to work all of a sudden? You can cycle your front to rear switch and listen to see if you can here it switch back and forth....
