need fe veteran knowledge
Old Dec 1, 2012 | 12:19 AM
cws10190's Avatar
cws10190
ok guys i got some questions for you. so it turns out i have a 428 std bore block. it has trw2245 pistons in it, im running a 268 comp cam, edelbrock rpm intake, a set of cobra jet heads ported polished bigger valves decked .010 and blended. msd distributor, hooker comp headers, 750 edelbrock carb. i am running a regular felpro gasket for a 390, dont even know if it will work with 428. what i would like to know where my hp and tq should be at. also how can i tweak more horse power out of it. should i balance crank, rods, and pistons, deck the block? the heads were used on a pulling truck with mechanical roller cam.
cws10190
Dec 30, 2012 09:55 AM
cws10190
Dec 4, 2012 09:50 AM
1969Highboy
Mar 27, 2009 02:25 PM
390cobrajet
52
Aug 18, 2007 11:45 PM
f600nightmare
Aug 6, 2004 11:59 PM
