My '54 F-100 shorted out. Turns out that the previous owner powered the heater switch by using a wire with alligator clips between the heater switch and the ignition key switch.
I would like to install the power wire to the heater switch correctly; can anyone describe:
1. Where the power wire to the heater switch comes from, and
2. Which terminal on the heater switch does the wire go to?
