$2000 spark plug change
Old Nov 30, 2012 | 11:10 AM
70f100longbed's Avatar
70f100longbed
Hey guys I figured I would share the truck I just got finished working on. The owner took it to a independent shop to get the plugs changed. They broke #3 and in the process of removing it they drove the ground shield further into the head. Also the 2 plugs they managed to changed has so much anti-sieze on them they were sure to misfire. It was everywhere, on the coil boots, the hex on the plug, and completely covering the plug from the top of the threads to the bottom of the ground shield. I had to pull the cylinder head and drive the broken plug out in 2 pieces. The porcelain came out through the combustion chamber side and I had to fold the end of the metal shield over with a punch and drive it out through the coil side. The plug was so far into the combustion chamber the electrode hit the piston and made a small mark in the center. Moral of the story, don't let amateurs change your spark plugs unless you have a fat wallet.
Old Nov 30, 2012 | 11:28 AM
21411's Avatar
21411
wow all the sudden that quote for $200 on my old (05 mustang) 4.6 does not sound bad.
did you really have to pull the cab?
Old Nov 30, 2012 | 11:56 AM
70f100longbed
Its faster to pull the cab. I had the head on the table in 3 hours.
Old Nov 30, 2012 | 01:13 PM
Stewart_H's Avatar
Stewart_H
The other shop is liable for their shoddy work.
Stewart
Old Nov 30, 2012 | 01:22 PM
70f100longbed
I agree but that's between the owner and the shop.
Old Nov 30, 2012 | 02:13 PM
Stewart_H's Avatar
Stewart_H
Of course, yes.
I was just making a statement of obvious fact.
It really is sad.
Stewart
Old Nov 30, 2012 | 02:27 PM
21411's Avatar
21411
wow, ok then
Old Nov 30, 2012 | 04:55 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by 21411
wow, ok then
It's a very common practice when there's is major engine work to be done.
You should see an Excursion with the body off.
Stewart
LaughingSavage
Modular V10 (6.8l)
Mar 4, 2022 04:54 PM
markvonn22
Modular V8 (4.6L, 5.4L)
Nov 22, 2015 08:05 PM
newbiemechanic
Sep 7, 2015 07:19 PM
Aoc230
1997 - 2003 F150
Jul 11, 2014 01:17 PM
cabldawg
3.8 & 4.2L V6
Dec 23, 2008 07:26 PM
