vent window replacement?
Old Nov 28, 2012 | 10:18 PM
|WYG|SS's Avatar
|WYG|SS
Angry vent window replacement?
Hey guys I got a 93 f150 and the other day at ork I accidently locked the key in the truck and I don't know where my spare is so of course I tried the old coat hanker in the vent window and I almost had it but I put a little to much pressure on the vent window and it shattered, now I have key less entry. :-)
My question is are these hard to replace by myself? Safelite wants $250 for just the window not including labor. On lmc truck I seen it for $100 so I might try I myself or go to a junkyard and pull one off
Old Nov 29, 2012 | 12:48 AM
Puddy's Avatar
Puddy
easy, i would personally go the lmc truck method
Old Nov 29, 2012 | 01:07 AM
Jacobs Daddy's Avatar
Jacobs Daddy
You would have been better just breaking out the entire rear window then taking a chance on the vent windows. It's a lot cheaper, I learned the hard way also. And I looked into doing it myself like you, but after doing research, I paid safelite.
Old Nov 29, 2012 | 03:22 AM
|WYG|SS's Avatar
|WYG|SS
I should have done the back window, cause it is a 1piece and I've always wanted to instal a sliding rear window. Lol...
On those vent windows they look easy justwhat I'm wondering is if i just drill those pivit points out.... I might take the door panel off tomorrow to see how the bottom one comes out. The top I can just replace with a small bolt then if i lock my keys in the truck I just pop that bolt off.... but I shouldn't need to cause I will have some spares made.
Old Nov 29, 2012 | 04:23 AM
deljac's Avatar
deljac
Go to a jy and pull one yourself. Its a 10 min job. Ther are 2 screws at the top and then ther are either 2 or 3 bolts behind the door panel. When you get them all out have your side window down and pull the whole wing window frame out.
Old Nov 29, 2012 | 07:10 AM
Intimnasc's Avatar
Intimnasc
I had a local glass company replace mine for 75 dollars. My son locked the keys in it and thought maybe I would be pissed if he called and told me so he thought it would be a better idea to bust the "little" window. Boy was he surprised how mad I was.
Old Nov 29, 2012 | 12:07 PM
|WYG|SS's Avatar
|WYG|SS
That sucks. It looks like the glas s is just $20 but for $99 you GT glass with framethe only other thing about the junkyard is I am picky aboutmy stuff.
Truck Parts and Truck Accessories
woodtrucker
Nov 27, 2013 10:31 AM
Shamus
Mar 2, 2009 11:20 PM
dblg
Apr 3, 2007 07:05 PM
95bogginbronco
1978 - 1996 Big Bronco
Nov 28, 2006 09:41 PM
