CEL Code P2074
Old Nov 28, 2012 | 08:07 PM
Olds69442's Avatar
Olds69442
CEL Code P2074
anyone else having trouble with this code. replaced stock air filter with aFe filter 10,000 miles ago. 20,000 on truck. threw code sunday dealer replaced filter with stock. said code may come back. which it did 5 miles later.
edge CTS says max boost is at 22 psi.
is this something i will live with or indication of something else?
Old Nov 28, 2012 | 08:19 PM
kper05's Avatar
kper05
You shouldn't have to live with a CEL over this.
Have you returned to the dealer after it threw the CEL with the stock setup?
Since it's now stock they need to troubleshoot it rather than tell you it may or may not return, IMHO.
I will say I have never seen my CTS show 22 PSI (stock filter).
I can get it to 21 PSI from time to time though.
Back before the CTS I used to think the gauge looked like 22 but the digital facts are better.
I'm sure you already know what this code is but for easy lookup by everyone else:
P2074 - Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher Load
Old Nov 28, 2012 | 08:48 PM
Olds69442's Avatar
Olds69442
i will call the dealer tomorrow see what they say.i had it looked at today and got my edge today.
i will say my boost gauge has moved to the right of the center mark and has that way for a little bit.
thanks for the advise
Old Nov 30, 2012 | 01:28 PM
Olds69442's Avatar
Olds69442
Follow Up; Turned out to be a bad mass air flow sensor.
Here is the read out from my Insight, must have been a one time thing.
Old Nov 30, 2012 | 02:17 PM
kper05's Avatar
kper05
Does the CTS always monitor max boost or did you have it recording?
I don't think I've ever been in the records screen on my device.
Old Nov 30, 2012 | 02:52 PM
Olds69442's Avatar
Olds69442
I just recieved and installed the CTS on Tuesday. I found that information under "records". I did an update of the software before I installed mine. Maybe it is in the update.
Old Sep 11, 2013 | 08:50 PM
sboller's Avatar
sboller
So what is the average cost on a MAF sensor? I'm sure that my extended warranty wont cover that at 52K miles? Any ideas?
rstinson
6.7L Power Stroke Diesel
Mar 17, 2018 04:26 PM
Restlesswildman
Jun 26, 2016 10:17 PM
Dr.Dan
Dec 12, 2010 09:05 AM
treagan
Mar 28, 2007 08:21 PM
wolfe1104
Jan 7, 2007 12:39 AM
