forced induction
Old Nov 28, 2012 | 07:42 PM
quincyj34's Avatar
quincyj34
forced induction
I have a 92 f150 4.9l and I've seen a couple online that have turbo. I just wanted to know how the stock computer would handle 5lbs of boost from either a turbo or supercharger.
Old Nov 28, 2012 | 07:54 PM
impish's Avatar
impish
My '96 had Mass Air; do not know when 4.9 got that, instead of Speed Density.
To answer your question, a Mass Air operating computer will handle forced induction just fine, but not Speed Density.
So, which have you got? impish
Old Nov 29, 2012 | 03:22 PM
quincyj34's Avatar
quincyj34
I believe its speed density
Old Nov 29, 2012 | 04:16 PM
Encho's Avatar
Encho
The Southernmost Mod
If it's the same as with the V8s, then only 95-96 will have the MAF system. And even then, some 95s won't.
Old Nov 29, 2012 | 04:38 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Right, same story with the 4.9. Might be that it's more definitively "1996 only" with the 4.9 - not sure.
So to answer the question, with a '92, not well at all. Frankly, that would be my answer with a '96 as well, as you might very well run out of fuel before you got to 5 lbs. Perhaps you'd be okay under 5 lbs, but I wouldn't try it unless I had another engine at the ready.
But again, with a stock speed density setup, all bets are off.
Old Nov 29, 2012 | 09:21 PM
quincyj34's Avatar
quincyj34
what if I add the module made by jet?
JET Performance Products, Import & Domestic Performance, Performance Kits, Fuel Systems, Transmissions
Old Nov 30, 2012 | 06:51 AM
DIYiT's Avatar
DIYiT
Chips on these trucks are useless. You need to switch to a Mustang ECU and use a Tweecer system if you want to modify a Ford MAP ECU for your application; you could also switch to a Ford MAF ECU to accomplish a similar goal.
Old Nov 30, 2012 | 09:45 AM
quincyj34's Avatar
quincyj34
So your saying I can use the same maf ecu thats on a v8 mustang and tune it to just run six cylinders?
Old Nov 30, 2012 | 10:10 AM
DIYiT's Avatar
DIYiT
Sorry... mixed up a forum post and forgot you were running the 300 i6. No, a Mustang ECU won't work. Best bet is to find a MAF 300 i6 or find an ECU for the 300 that is compatible with the Tweecer tuner.
Old Nov 30, 2012 | 10:22 AM
Blown349's Avatar
Blown349
You might get away with a stock set-up and maybe 5 lbs. of boost. I tried 6lbs with a 302 and speed density and a fuel management unit, everything else was stock, it idled bad, and the power was real peaky. Speed density can only go so far and can't really measure the extra air you are pushing in. I tried it knowing I had another build on the way.
You would need a tune/tuner for more and there are very few that would tune a 6 cylinder with speed density. It would be worth a call to Mike Glover, owner of Tweecer, to see if he has a "Strategy" available which is used to tune the inline 6 with Speed Density or MAF. MAF being the better way to go.
Then you wouldn't be able to run much boost without upgraded fuel delivery - higher volume pump and larger injectors. You'd probably also want a better cam, intake, and exhaust to get the most out of the boost.
The TwEECer -- EEC-IV user programmable module
The Mtn Bolt - 93, F150, Flare Side, Short Bed, 4X4, Tweecer Tuned, Built/Blown 351W, Punisher E4OD, 4" lift, 33's on Hurricanes.
Old Nov 30, 2012 | 10:00 PM
impish's Avatar
impish
V-6 MAF
A computer made to run a V-6 having MAF could be adapted to the inline engine without a hair-pulling hassle, if the installer knew WTH was going on......
Bigger the V-6 the better, a 4.0 Ford, like Explorer would likely do, but sufficient fuel would have to be made available.......
Easiest would be to get the EFI set-up off a '96 F-150 with 4.9L, use it on your existing engine, then huff away!
impish
Old Dec 1, 2012 | 05:13 PM
quincyj34's Avatar
quincyj34
thanks for the info guys. Now I have one last question. A turbo 4.9 would be great how would it compare to a 351 EFI especially in terms for gas since this would be a daily driver with occasional hwy trips about 60 miles and occasional boat towing?
JRS2
Feb 13, 2016 01:54 PM
1990fordbronc
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Feb 19, 2006 10:19 AM
69ford99
23
Feb 10, 2006 09:30 PM
4x4man514
Jan 16, 2005 02:24 AM
broncobilly72
Jan 19, 2004 10:10 PM
