73 died while idle at light
Old Nov 28, 2012 | 04:01 PM
savagehenry's Avatar
savagehenry
Truck had been running great lately, but died last week at a red light. Towed it home, was able to start the next day with difficulty, but died in idle after about 30 seconds. Fuel pump seems to be working fine.
Any ideas would be appreciated.
Coil? Module?
Thanks
Old Nov 28, 2012 | 04:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
'73 shouldn't have a module, it should be points and condenser.
Check to see if you have spark. If there is none clean the points and check the gap. 6cyl .025" V8 .017"
Old Nov 28, 2012 | 04:46 PM
savagehenry
No points, ignition was converted by a previous owner.
Old Nov 28, 2012 | 05:04 PM
HIO Silver's Avatar
HIO Silver
A carb float with a pin hole... but we can guess all day.
.. what hands-on troubleshooting have YOU done?
Old Nov 28, 2012 | 05:52 PM
savagehenry
With my experience/knowledge being extremely limited I have:
-Checked that the fuel pump is working
- Inspected one spark plug from each side, both appeared normal
- Inspected the rotor/cap which looked okay
Old Nov 28, 2012 | 05:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Pull the coil wire out of the distributor cap and hold it about 1/4" away from the intake manifold. Have someone turn the engine over and watch for spark, you should have a strong blue/white spark.
Biggreendiesel02
Apr 10, 2025 10:30 AM
Tyler Labaume
Oct 21, 2016 02:16 AM
navistardiesel
Sep 2, 2015 07:54 PM
rcassettyjr
Jun 21, 2007 06:58 PM
jad79ford
Jul 11, 2006 03:54 PM
