Hey gents i need your help again one of the red dials on my 76 hiboy is broken and i cant lock my wheel. my napa said its a dealer part my ford dealer said he doesnt have any so where can i buy one? i need to use 4x4 before winter gets here.
Is it broken where the pin goes through the ****? if so, that can be easily repaired with a piece of PVC pipe, otherwise the junkyard is your best bet for a used ****.
If your heart's set on a NOS **** JST Automotive in TN. has (1) 50 bucks.
Since there is only ONE available NOS, I didn't want to post the source as someone else might snag it. You just "let the cat oughtta the bag."
I think that is a C8TZ-1A029-A which is the turn *** for the 68-72 dana 44. He needs the D2TZ-1A029-A like Bill stated. This one will not work for him. He has a dana 44HD.
Originally Posted by twinzilla
Not sure if this is the one you need, but you can have it for $35 shipped if it'll work for you.
Thanx for the help gents. i really dont like the idea of paying $50 for a little plastic part so i think i will try repairing it. how do i fix it with the pcv pipe?
That pipe fix worked out great thanx montana_hiboy i love a $2 fix! but i need your gents help again. the rubber seals around the red dials are brittle and cracking and i cant find these anywhere either. canu you help? plus when i took them apart they were filled with watery oil. shouldnt there be some kind of grease in there? what should i use when i repack them? thanx
