Technical help rear end
Old Nov 27, 2012 | 03:53 AM
Mr.Haney's Avatar
Mr.Haney
If this is in the wrong spot I apologize. But need help I have a 1975 F-250 crew cab 2wd and want to know if a 1978 f-250 4wd rear end will bolt in my 75 ? Any help would be appreciated
Old Nov 27, 2012 | 03:27 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
No you are in the correct year and dept for some help, it should with no problem that I can see.
Ck the old rearend gear tag ratio versus the new rearend tag, a gear change might be in order after wards?
Only because their might be a big difference in the ratio? But if they are close you should not notice it.
RedneckRenegade91
Jul 19, 2014 12:14 AM
jeff1089
Dec 3, 2007 05:39 AM
jcubi@sbcglobal.net
Mar 29, 2004 10:18 AM
1980F100
Sep 10, 2002 05:06 PM
Hunter64
Jun 26, 2001 06:43 PM
