Tryed pulling some codes
Old Nov 26, 2012 | 06:15 PM
Onus's Avatar
Onus
I was curious as to why my transmission shifted so nice then went right back to normal after the tps change. I also heard that the early e4ods will not flash the over drive light when there is a problem. Mine was not flashing.
Here are the code results:
26
TOT out of self test range. My guess is this is due to me having the truck 3 days dead cold and not warmed up.
23
Closed throttle TPS voltage higher or lower than expected. Was going to adjust it more anyway.
Continuous codes:
62 converter clutch error
This sucks... It does slip at 35mph.
67 neutral safety circuit failure.
I looked this up and it needed to be in neutral and not park and that was the cause.
Old Nov 26, 2012 | 06:29 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
the TOT sensor out of range.it failed or the wire going to it in the pack is making a poor connection.
you won't get this code because the fluid is cold.the sensor will just tell the pcm it's cold based on resistance values.
so what i would do,is look up which pin on the pcm harness and the solenoid plug,and ohm out the wire,to make sure it's all good.if this wire doesn't ohm out 0 between the pcm pin and pack plug,you can run a new wire and pin it in.personally,in this case,id question the rest of the wires,and buy a new harness.
then i'd figure out a way to test the sensor with an ohm meter (if i didn't find a brake in my wire.) i guess id unplug the pcm end,and then probe the pin(s) needed here to check the tot resistance values,or maybe even probe into the wire/pin itself at the pack plug to make sure the tot is bad.if so,then id swap out the pack with a used salvage yard one if funds are low.-just as long as you test all the solenoids first or at least get a few day return policy on it.personally id go with a rebuilt pack online.
this all done after i would double check the condition of the pack plug,and made sure it was spotlessly clean with electrical cleaner,and coated with dielectric grease.
in another thread,we know your TPS/FIPL settings are off and should be tweaked better.but don't forget this code will be set if you don't hold WOT with the idi engine.
Resistance/Continuity Tests � Transmission Fluid Temperature (TFT) Sensor
Set ohmmeter to 1000-ohm (k) scale.
Connect ohmmeter positive lead to TOT+ jack.
Connect ohmmeter negative lead to TOT- jack.
Record resistance. Resistance will vary with temperature.
Refer to the following chart.
TFT SENSOR RESISTANCE SPECIFICATIONS Temperature Resistance
°C °F (Ohms)
(-)40-(-)20 (-)40-(-)4 967k-248k
(-)19-(-)1 (-)3-31 248k-100k
0-20 32-68 100k-37k
21-40 69-104 37k-16k
41-70 105-158 16k-5k
71-90 159-194 5k-2.7k
91-110 195-230 2.7k-1.5k
111-130 231-266 1.5k-0.8k
131-150 267-302 0.8k-0.54k
Last edited by FORDF250HDXLT; Nov 26, 2012 at 06:42 PM. Reason: finding some diagrams to help....and resistance specs
Old Nov 26, 2012 | 06:50 PM
Onus's Avatar
Onus
Thanks, yeah i know the tps needs to be fixed. Gonna do it tomorrow when i throw the new alternator in. I did hold down the throttle. Well with a block of wood but it was full throttle.
I'll do all the checks you suggest. I'll get a new / rebuilt pack if it is needed. Thanks a ton!
Alcaeus
Aug 6, 2016 09:48 AM
markes12344
Dec 21, 2013 03:20 PM
KcinMI
Feb 5, 2005 07:13 PM
tfrain
Apr 8, 2004 08:10 AM
MrPleasant
Feb 17, 2002 11:12 PM
