rough idle and black/white smoke also some low power at low rpm
#48
#49
#50
Yes that would cause your Comdition
Cause Low Boost and overfuel
Did you have Coolant at the EGR Valve??????????
Are you shure Ypipe is Broken
or Bad Clamp???
There are also a Flexjoints that like to crack and leak on the Uppipes
Might as well put new exhaust manafold gasket on if have to pull to replace broken Bolt this Might be Fun one to get broke bolt out
What PSI Boost you see High side things
#51
#52
#53
FVP-10.5-12.5
PSI-13.9-14.0
FM-49
FLP-11.5
VLT-12.5
EBO- not reading anything.
I ran out of time ill try to input the others later.
#58
#59
Here's a thread where I did my oil cooler and installed the BPD EGR cooler and STC update on my '06. Lots of pictures and a few good tips from members along the way and some torques and stuff. Nothing specific to the BDP delete though.
https://www.ford-trucks.com/forums/1...many-pics.html
#60
OIL COOLER REBUILD INFO
TURBO REMOVVAL
https://www.ford-trucks.com/ford-man...%20Removal.pdf
INTAKE MANAFOLD REMOVAL
https://www.ford-trucks.com/ford-man...%20removal.pdf
OIL COOLER REMOVAL
https://www.ford-trucks.com/ford-man...er_Removal.pdf
OIL COOLER NAVSTAR
https://www.ford-trucks.com/ford-man...20Navistar.pdf
OIL COOLER REPAIR
https://www.ford-trucks.com/ford-man...r%20Repair.pdf
TURBO REMOVVAL
OIL COOLER REMOVAL
OIL COOLER NAVSTAR
OIL COOLER REPAIR
