rough idle and black/white smoke also some low power at low rpm
  #46
Old 12-01-2012, 04:04 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
Is the smoke coming from exhaust Jiont or S.H.I..T. On the pipe
  #47
Old 12-01-2012, 04:11 PM
BLADE35's Avatar
BLADE35
Where all the sensor Values
I just skim read back but didnt see any did I mis????????????
  #48
Old 12-01-2012, 04:18 PM
BLADE35's Avatar
BLADE35
Post
ICP
ICPV
IPR%
FICM MP
FICM VP
FICM LP
BARO
MAP
EBP
Volts
Post 3 values for each sensor
KOEO
Low Idel
High Idel (2500RPM)
EOT around 190* Truck in Park or neutral
  #49
Old 12-01-2012, 04:43 PM
freaknasty799's Avatar
freaknasty799
freaknasty799 is offline
Hey guys I don't think water is an issue. I just found that I have a header bolt out and my y pipe is broken. I think the coolers being bad is aiding the white smoke and the broken bolt on header is allowing the smoke to come through there.
What do you all think?
  #50
Old 12-01-2012, 04:48 PM
BLADE35's Avatar
BLADE35
Yes that would cause your Comdition
Cause Low Boost and overfuel
Did you have Coolant at the EGR Valve??????????
Are you shure Ypipe is Broken
or Bad Clamp???
There are also a Flexjoints that like to crack and leak on the Uppipes
Might as well put new exhaust manafold gasket on if have to pull to replace broken Bolt this Might be Fun one to get broke bolt out
What PSI Boost you see High side things
  #51
Old 12-01-2012, 04:52 PM
BLADE35's Avatar
BLADE35
Hang a Peice of string on a Stick and watch for to blow around
You can Also Fill for leaks by hand if Cold start be Ready to check Fast though before it gets Hot this How I check Mine
  #52
Old 12-01-2012, 05:24 PM
freaknasty799
Thanks Benny. Ill try to input all those values and let you know as soon as I can. I think it's is the flex pipes. I'm not sure on the boost I never really watched it.
Can u post parameters for those values?
  #53
Old 12-01-2012, 05:59 PM
freaknasty799
Originally Posted by BLADE35
Post
ICP
ICPV
IPR%
FICM MP
FICM VP
FICM LP
BARO
MAP
EBP
Volts
KOEO
Low Idel
High Idel (2500RPM)
BAR-14.2
FVP-10.5-12.5
PSI-13.9-14.0
FM-49
FLP-11.5
VLT-12.5
EBO- not reading anything.
I ran out of time ill try to input the others later.
  #54
Old 12-01-2012, 06:02 PM
BLADE35's Avatar
BLADE35
If the truck was at Normal Temp the Voltage shure is Low
Was all these taken when Cold???
  #55
Old 12-01-2012, 06:33 PM
freaknasty799
Yeah the truck has been sitting for a few days and these are cold.
  #56
Old 12-04-2012, 12:06 PM
freaknasty799
Hey guys! Ok so my sinister oil cooler and delete arrived today. Any help on the install would be great.
Thanks!!
  #57
Old 12-06-2012, 03:09 PM
freaknasty799
I have started tearing into this. I can't seem to find good instructions on doing the egr delete and oil cooler
  #58
Old 12-06-2012, 07:05 PM
04badford's Avatar
04badford
04badford is offline
Hey Freaky N Im shue some body will post a place to read up but for now go to the top of this page in tech guides there are threads to read up on Cheezit and Bizmic has some input on egr delete and oil cooler. Hopfully Blades will be chiming on soon he aswell will know.
  #59
Old 12-06-2012, 08:03 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is online now
Here's a thread where I did my oil cooler and installed the BPD EGR cooler and STC update on my '06. Lots of pictures and a few good tips from members along the way and some torques and stuff. Nothing specific to the BDP delete though.
https://www.ford-trucks.com/forums/1...many-pics.html
  #60
Old 12-06-2012, 10:16 PM
BLADE35's Avatar
BLADE35
Quick Reply: rough idle and black/white smoke also some low power at low rpm
