Excursion Front Differential, Type and Value??
Old Nov 26, 2012 | 12:06 PM
XbigXredX's Avatar
XbigXredX
Hi all, need some quick help. Can anyone tell me what type of front differential is in my 2000 V10 Excursion, (dayna 50 or 60 I have heard) and what the value is for a used front differential including the axles. Thanks in advance!
Old Nov 26, 2012 | 12:18 PM
WE3ZS's Avatar
WE3ZS
Dana 50. Values vary for various reasons, I bought a set of front/rear EX housings setup with 4.88 gears and a rear locker earlier this year for $1200.
Old Nov 26, 2012 | 12:43 PM
XbigXredX's Avatar
XbigXredX
I'm in the process of parting out a tree fell on me 2000 X and someone offered $400 for the front differential, with the shafts, and $100 for the rear. I know the rear is too low imho but the front I'm not sure on, that's why I figured I'd ask here.
Old Nov 26, 2012 | 03:22 PM
rla2005's Avatar
rla2005
If your rear axle has factory limited slip, that would bring more $$. I would also hazard a guess to say if you have 4.10 or 4.30 gear ratios, that would also bring a premium price too.
Old Nov 26, 2012 | 04:00 PM
zato666's Avatar
zato666
XbigXredX
Do you have a thread on the parting out of your truck?
Old Nov 26, 2012 | 05:55 PM
XbigXredX's Avatar
XbigXredX
Factory limited slip, how would I know?
3.73 Gears that I know.
Originally Posted by zato666
XbigXredX
Yes I do-
https://www.ford-trucks.com/forums/1...available.html
And I am in the process of adding pictures.
Old Nov 26, 2012 | 09:07 PM
family xj's Avatar
family xj
4.88 gears is what I should have got to run my 44's. I went 5.13's and its too much so I may have to lift more and run 47's
Old Nov 27, 2012 | 08:00 AM
rla2005's Avatar
rla2005
Axle Codes for '99 and up Super Dutys
Codes are located on The Vehicle Certification Label located on the driver's side door jamb.
F-250 / Excursion
3.73 31 - Open Diff C1 - Limited Slip
4.10 32 - Open Diff C2 - Limited Slip
4.30 33 - Open Diff C3 - Limited Slip
Old Nov 27, 2012 | 10:50 AM
EXv10's Avatar
EXv10
Yes I do-
Look for a tag on the diff. 3.70's won't bring as much.
Old Nov 27, 2012 | 12:26 PM
XbigXredX's Avatar
XbigXredX
How much would the 3.73 be worth? Thanks!
Old Nov 27, 2012 | 02:01 PM
EXv10's Avatar
EXv10
I don't know, call some wrecking yards.
Old Nov 28, 2012 | 06:05 PM
XbigXredX's Avatar
XbigXredX
3.73
4.10
4.30
What do they do better than each other??
Old Nov 28, 2012 | 08:07 PM
EXv10's Avatar
EXv10
3.73
4.10
4.30
The 3.7's are pretty standard and give the best mileage on the average truck but there are a lot out there, and the higher the #, the lower the gearing so a 4.10 would be better for towing etc. A 3.73 ratio gear-set will spin the pinion gear 3.73 times for every 1 spin of the ring gear etc. The lower (higher numerically) the ratio is the more RPM the engine will spin at a given MPH.
Old Nov 28, 2012 | 08:14 PM
XbigXredX's Avatar
XbigXredX
And Ford just arbitrarily put these rears in different trucks with no rhyme or reason? I mean my 02 has 3.73's. 2 of the three 00 have 3.73's and the third 00 has 4.3's. No rhyme, no reason, just that they felt like doing that? Sorry if I sound stupid, just trying to grasp the concept.
Old Nov 28, 2012 | 08:36 PM
EXv10's Avatar
EXv10
Normally anything other than 3.7's are special ordered when the truck was new. (optional).
