1966 - 1977 Early Broncos
1969 Driveline Phase
Old Nov 25, 2012 | 08:48 PM
a12play12's Avatar
a12play12
Hey Guys,
I am usually in the super duty section, but have an early bronco question. I am currently restoring a 69, 302, 3sp manual. The drive lines when removed appear to be 45 degrees out of phase?!?!?!?! I used the search and did not see anything on this. is this normal for these??? i have the early Borg-Warner shafts. it appears that the splines are out of phase, but i find a picture of a new drive line that looks the same. I only drove the bronco once before dis-assembly, and do not remember any vibration. What are your thoughts????????
Thanks in Advance, Roger.
Old Dec 8, 2012 | 08:49 PM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I would think they should be lined up. I have never heard of any driveline that is suppose to be 45 degrees out of phase.
Old Dec 10, 2012 | 11:01 AM
a12play12's Avatar
a12play12
I agree Tom, but i found a picture of a new driveline at toms that looks out of phase like this one!?!?!?!?!?!? It is both the front and rear that are out of phase. This is definately odd.
Roger
Old Dec 12, 2012 | 06:42 AM
Boba Fett's Avatar
Boba Fett
The driveline is usually offset to avoid vibration.... The engine is set more to the passenger side if you look carefully.... Just run what you have and you will be fine...
Old Dec 12, 2012 | 11:18 AM
a12play12's Avatar
a12play12
Excellent, Thank You for your help!!!
Roger
Old Dec 13, 2012 | 09:12 PM
Tim Young's Avatar
Tim Young
There ya go learn something ever day. Is the Driveline in my 69' supposed to be out of phase?
Old Dec 15, 2012 | 12:19 PM
chrlsful's Avatar
chrlsful
out of phase?
Is this a chebby thing or what (I don't think so)? I'm ignorant. Drive shafts have lill weights welded on them for balance, not familiar w/ the splines needing to line up in some cases or what this "phase" idea is... Also not sure "off center" motors/trans/transfer etc apply to this original poster's Q (Subie is the only modern vehicle I C regularly w/equal length drive shafts). Thanx-
Old Dec 15, 2012 | 02:27 PM
Tim Young's Avatar
Tim Young
I have never heard of a driveline being out of phase either. Maybe that's not what Bob was referring to, but I'm sure that's what the OP was referring to.
Old Dec 16, 2012 | 07:45 AM
chrlsful's Avatar
chrlsful
just goin round in circles now, no info.
if a12play12 returns may B clarity w/him...
Old Dec 17, 2012 | 11:06 AM
a12play12's Avatar
a12play12
What i am talking about is on every driveline i have ever seen, the u-joints are in a line down the shaft. On the drivelines on this bronco, the rear u-joint is about 45 degrees out of line with the other joints.
sorry for any confusion
Old Dec 17, 2012 | 11:34 AM
Tim Young's Avatar
Tim Young
That's what I thought you were talking about in the first place. I don't think it is right. Line the U-joint up.
Old Dec 17, 2012 | 10:44 PM
chrlsful's Avatar
chrlsful
Thanks 4 da post back!
"...the splines are out of phase..."
"...the rear u-joint is about 45 degrees out of line with the other joints.
sorry for any confusion..."
Ah, OK, thanks! Good luck with the project. Let us know how it goes (as it progresses) if you'd like. 'd be interesting (4 me anyway) not enuff bronks on here. Thanks...
Old Dec 18, 2012 | 09:58 AM
a12play12's Avatar
a12play12
I will let you know what happens. We are waiting on the body to be finished so it may be a while, but i will post the final results!! Thanks as always for the advise!!!
Roger
BigBird88
1978 - 1996 Big Bronco
16
Apr 16, 2018 06:11 PM
dines78
Dec 10, 2012 07:35 AM
for46016
Mar 3, 2010 12:38 PM
jesta302
Feb 17, 2005 06:21 AM
iftbronco93
Dec 12, 2003 07:27 PM
