1978 - 1996 Big Bronco
vibration at 35 mph
Old Dec 11, 2003 | 10:03 PM
iftbronco93's Avatar
iftbronco93
vibration at 35 mph
My Bronco has a vibration at around 35 mph when there is a low amount of tor
Old Dec 11, 2003 | 10:06 PM
iftbronco93
My bronco has a vibration at around 35 mph when there is a low amount of torque on the drive train. Diff. is good, tires are balanced and the vibe goes away as soon as you stomp the gas or let off of it. Anyone have any ideas.
Old Dec 11, 2003 | 11:04 PM
msuforeman's Avatar
msuforeman
Check your drive shaft u-joints. It just so happens mine did this about 2 weeks ago and it was the u-joint on the rear ds on the pinion. Mine was vibrating at 30-35 mph.
Brian
Old Dec 12, 2003 | 12:02 AM
dblue351's Avatar
dblue351
I would put money on the driveshaft u joints.
Old Dec 12, 2003 | 01:46 PM
iftbronco93
vibration at 35 mph (u joints)
I took my drive shaft off and inspected the u joints and seem to be okay. I am going to reinspect them and a friend told me to try rotate the drive shaft 180 degrees and see if that helps.
Old Dec 12, 2003 | 03:07 PM
msuforeman's Avatar
msuforeman
Look at them very closely(with a flashlight)--paying attention to the caps.
Old Dec 12, 2003 | 07:27 PM
dblue351's Avatar
dblue351
with the driveshaft on the truck grab it and shake it. You should have zero movement. If it even moves a little one or all of the u joints are bad.
