egr is plugged
Old Nov 25, 2012 | 03:12 PM
built tough's Avatar
built tough
egr is plugged
well guys looks like it happened my truck has 173000km and the dreaded engine light came on with the code for the egr being plugged. starting to lose coolant and blow white smoke. My question is if im deleting it should i just go the extra distance and put new head gaskets in and stud the motor at the same time so I dont get double hit with labour cost down the road?
Old Nov 25, 2012 | 04:55 PM
BLADE35's Avatar
BLADE35
Has it been Hydrolocked??????????????
Must Do Oil Cooler R&R To
Old Nov 25, 2012 | 05:43 PM
built tough
still runs perfect just noticed the coolant has now dropped below its sweet spot in the degas bottle
Old Nov 25, 2012 | 08:22 PM
MisterCMK's Avatar
MisterCMK
Follow the list in the tech folder and find your problem rather than throwing parts at it.
Old Nov 25, 2012 | 08:27 PM
BLADE35's Avatar
BLADE35
BE Worth pullen EGR Valve for a Look to
what is the exact DTC you get????
Old Nov 25, 2012 | 08:35 PM
MisterCMK's Avatar
MisterCMK
https://www.ford-trucks.com/forums/1...nts-degas.html
Read this and follow the list.
Old Nov 26, 2012 | 03:53 PM
built tough
Im pretty sure it was P0404 Exhaust Gas Recirculation "A" Control Circuit Range/Performance
But im not certain im no longer home I had to go back to work.
Oryo
Jan 25, 2021 08:44 PM
Brad Wissinger
Oct 23, 2016 05:38 PM
KC Excursion
Mar 12, 2012 11:37 PM
mkoser
Feb 15, 2012 08:59 PM
Drake430
May 26, 2011 07:39 PM
