AE hookup problem, wtf???
Old Nov 25, 2012 | 01:57 PM
nlemerise's Avatar
nlemerise
Hi,
I have been using AE for the last four years with zero problems on my Sony laptop. Today, I decide to hook it up to the truck (after not using it for about a year) to give it a general health check...here is what I have:
e99 F-350, 7.3l
Sony laptop running Windows Xp pro
AE Scantool V 9.1.1
Here are the settings I have in Scantool (communications):
USB or manually set serial port
Vehicle interface type: J1850PWM
Initialization type: Non-OBDII
FastMode NOT selected
HeartBeat NOT selected
Cigarette lighter has power, so I assume OBD port has power.
When I hook the dongle up to the laptop, the laptop sees it. When I try to connect to Scantool (either manually or set the option to automatically connect at start up) it scans for the dongle across ports, but never finds it. I have tried to connect at least 20 times with the KOEO and have had no luck. Can anyone cut this old guy some slack and point me in the right direction?
Oh and I remember I use to be able to set the vehicle parameters (1999, Ford, Powerstroke 7.3) but now that option is grayed out.
Old Nov 25, 2012 | 02:05 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Neal, I had to take down the firewall on my computer to get it to read AE. Hope it is as easy as this.
Old Nov 25, 2012 | 02:09 PM
Tugly's Avatar
Tugly
It's not NON-OBDII... it's OBDII.
Old Nov 25, 2012 | 02:11 PM
nlemerise's Avatar
nlemerise
Thanks Rick, but no luck.
Old Nov 25, 2012 | 02:18 PM
nlemerise's Avatar
nlemerise
Change made to Communications:
Initialization Type: OBDII Compliant
Still doesn't see the OBD port...Does anyone know what pin on the port supplies DC voltage? Found it...Pin #16 is battery +
Old Nov 25, 2012 | 02:23 PM
Tugly's Avatar
Tugly
OBDII - On-Board Diagnostic's System - Does My Car Have OBD-II? The Connector and Communications.
I tried calling both your numbers... give me a buzz. (get it?)
Old Nov 25, 2012 | 03:19 PM
Feonix1123's Avatar
Feonix1123
speaking of obd2 and ae does the ae software use just any obd2 usb cord or does it have to be a certain kind of plug to make the program work? thanks
Old Nov 25, 2012 | 03:43 PM
nlemerise's Avatar
nlemerise
AE comes with its own OBDII plug that must be used, AFAIK.
Old Nov 25, 2012 | 03:44 PM
nlemerise's Avatar
nlemerise
Problem is solved...looks like it was a corrupted AutoEngenuity.log file
Thank you Rich!
Old Nov 25, 2012 | 03:50 PM
Feonix1123's Avatar
Feonix1123
okay cause a friend found a old copy of his ae scanner but no cable and i was wondering if i could just buy a cable untill he gets his back i was just wondering..
Feonix1123's Avatar
Feonix1123
Thank you Rich!
GOOD DEAL DUDE
Old Nov 25, 2012 | 04:25 PM
Reckless's Avatar
Reckless
My understanding reading up on the thing b4 buying mine, was that the cord was the real expense of the thing and that it was not sold separately?
Old Nov 25, 2012 | 06:08 PM
nlemerise's Avatar
nlemerise
Would someone give Tugly some reps...Please?
Old Nov 26, 2012 | 09:45 AM
F250_'s Avatar
F250_
I just shot Rich a few reps on your behalf.
Old Nov 27, 2012 | 09:14 AM
Tugly's Avatar
Tugly
Thanks guys! For once... I get the opportunity to pay some of this direct help forward.
