1967 F100 4BT cummins daily driver build
#182
#185
Spent some time making the boxing plates for the frame yesterday and today. Cut the holes and dimpled them on the press. I also filled a BUNCH of holes on the outside of the frame and ground them smooth. I need to prime and paint the inside of the frame before I weld the plates on. I also need to make the end plates for the tranny cross member.
#188
#189
Thank you.
#190
#191
on
Your work is first class amgio, that takes talent, a steady hand, good eyes, patience, and a brain firing on all 8 cylinders... Did you make the lightening holes, or is that from WWII landing mats? That old stuff is made from 10 ga. steel, and there is still tons of it laying around..
Whichever, you do really nice work... well done
Baja
Baja
#192
Baja
Baja
#193
LOL, those plates look familiar, turned out pretty nice.
So, i'm kinda stuck on what to do for crossmembers and wondering what your plan is?
I'm thinking narrowing the originals and attaching them to flat plates which will bolt to each side of the frame. I'll sleeve the new boxed frame so the bolts will go all the way through both sides.....thats the plan...so far
Pretty sick of researching this frame stuff, I'm just gonna jump in and try it.
#194
I only have 3 cross members. The one for the front suspension, the one between the rear notch, and the one for the back cab mounts which I am going to slightly beef up and weld in. Not planning on doing any others since it is a short bed and will only see road use. I'm sure everything will be plenty stiff for that. Definitely much more rigid than the original frame.
