Shorter antenna??
Old Dec 6, 2012 | 10:33 PM
mpally's Avatar
mpally
Originally Posted by SuperDutyScaler
Ford does this for a reason, so the driver sees it before they run into something with their roof! My factory antenna has saved the roof of my F350 sssssooooo many times its not funny, everything from a drive through to parking garages.....
I cut off several inches and the antenna is still higher than the cab of the truck. If that's the purpose of the long antenna, then they should shorten it closer to the actual height of the truck. If it is 5 or 6 inches higher than the cab, what good does it do as you will not pay attention when the antenna hits the overhead obstruction. The antenna was hitting beams that had 6' 9" of clearance. The height of the truck is around 6' 4". It seems excessive to have that much difference.
Old Dec 7, 2012 | 10:17 AM
SuperDutyScaler's Avatar
SuperDutyScaler
really? even with cab lights my stock antenna is about two inches taller then that, but i have a F350 so maybe they are different antenna's.....
Old Dec 8, 2012 | 11:33 PM
TheStuffz's Avatar
TheStuffz
I was in the parkade at the cornwall in regina today. every time that antennae hit the cement roof i was nearly having a heart attack. had to get out and see how much room i had!
Old Dec 9, 2012 | 12:59 AM
Jake85388's Avatar
Jake85388
Agreed, some things are best left alone because there is a reason it is made the way it is.. But it does **** me off when it hits in the garage, now it's lifted so can't park in there anyways, I say lift the truck higher so u can't park in spots that would allow u to hit it on anything to begin with......
I'm kidding of course lol ....
I think cutting it down is prob just fine......
Truckie256
May 20, 2018 10:05 AM
Chris Stromer
General Automotive Discussion
Jul 7, 2017 08:06 PM
gadiedrick
Dec 17, 2016 01:15 AM
UWMtriebs
Dec 23, 2009 03:19 PM
drtry10
Sep 1, 2008 08:48 PM
