LIke FortyNiner says,,,,,,,,,,,,,,,,,,unless it is set up as a marine engine, then it might be set up to rotate the other way. Who knows what someone may find in an old boat shed.
thanx fellas ,one down ,truck start fine after it runs awhile or a nice drive i turn it off and it will not start. i wait afew hours then it start right up. 6v pos ground seems like the engine has to be cool it wont start when it hot
Well it depends on whether you're talking about humans or cars.
It's a scenario where the heat from the engine essentially vaporizes the liquid fuel within the fuel system. As a result, the fuel pump does not maintain proper fuel pressure and steady flow of gasoline to the carb.
how do you fix that problem and i will check my coil
Believe it or not a old way of stopping vapor lock was to put a grapefruit half after you have taken the fruit out on the fuel pump bowl. Acts as grate insulation may not smell real good after a while but it does work. Dave s
Hey Mike,
Your truck looks great - I like the red & black combination - Nice.
I wish I could help you with your - not starting problem but I've got a
more modern drivetrain 351W/AOD. What engine do you have in there?
