Mileage update
Old Nov 23, 2012 | 09:53 PM
mcallister's Avatar
mcallister
Mileage update
Just turned 350,000 on monday. Just thought I would let you all know. Keep trucking fellas! : )
Old Nov 23, 2012 | 10:02 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
350,000 trouble free miles or after a butt-load of work?
Josh
Old Nov 23, 2012 | 10:13 PM
mcallister's Avatar
mcallister
Let's see, trouble free......ah, no. All of the injectors have been replaced, head gaskets, radiator, on second turbo (replaced at 92k, so not that bad), alternator.......original water pump which is amazing to me. Hmmm, tranny is original. Crazy thing, this is a work truck. I pull 14-16K pound form trailers (concrete foundations forms) quite often, in fact, in 2004-2006, I worked 7 days a week. We had more crews than trucks, so I had to scoot trailers on the weekend to the guys' next job. Tranny is starting to slip a little, kinda of sad. : ( But, for a 6.0L, these miles are pretty impressive to me!
Old Nov 23, 2012 | 10:30 PM
bismic's Avatar
bismic
congratulations. how long did the injectors last?
Old Nov 23, 2012 | 10:32 PM
Bullitt390's Avatar
Bullitt390
350,000 miles on the original oil and EGR cooler?
Still that's not a lot of work for that many miles. What is your maintenance routine?
Josh
Old Nov 23, 2012 | 10:35 PM
mcallister's Avatar
mcallister
Ok, we ended up replacing them in pairs. Ist two at 220K, 2nd pair at 260K, 3rd pair at 290K, then last two at 335K.
Old Nov 23, 2012 | 10:36 PM
bismic's Avatar
bismic
Not much wrong w/ early EGR coolers, but that brings up a good question - what coolant have you been using?
Edit -
Pretty darn good on the injector life!!!
Old Nov 23, 2012 | 10:40 PM
mcallister's Avatar
mcallister
Josh
Oil and EGR cooler was replaced at 270K I believe. Maintenance is tranny, transfer case, rear end fluid and filters have been replaced at 60K mile intervals using Amsoil products. Fuel filter is replaced at the same time. Oil.....well, lots are going to think I am nuts, but for 160K miles, I did 20K mile oil drain/5K mile oil filter. I was doing 55-60K a year and felt bad how often the oil was being changed. I am back to 10K mile oil/5K oil filter, since I am doing a little less driving these days. Still on track to do 45K this year. I have used Rotella T 5W-40 since 61K miles.
Old Nov 23, 2012 | 10:42 PM
mcallister's Avatar
mcallister
Edit -
Coolant, Motorcraft. We have learned (we have (7) 6.0L and (10) 7.3L, and have always used Motorcraft coolant.
Old Nov 23, 2012 | 10:49 PM
bismic's Avatar
bismic
Good to know! Many are quick to get on the "Ford Gold is junk" bus ........
Old Nov 24, 2012 | 02:43 PM
woodlander's Avatar
woodlander
Thanks for posting! I always like to hear about long life 6.0's. If I have to replace a few parts to get 300,000 miles thats OK. And I think a lot of us on this site have followed Bismic's and others recommendations on maint intervals which should help even more. Much appreciated.
Old Nov 24, 2012 | 08:18 PM
mcallister's Avatar
mcallister
No problem, I gotta tell ya though, it's been crazy dependable for the most part. If anyone on here knew where I have been with this truck.......it's crazy. It runs 12-14 hours a day at a minimum, now 5 days a week. How much I have pulled with it is crazy to boot! Rotella T synthetic I think has played a big part.
batchman
Dec 30, 2015 08:14 AM
kevind95
Dec 13, 2012 12:19 AM
Crew-it
Aug 7, 2012 10:26 PM
suzuki_vinson
Sep 27, 2007 07:49 PM
DShepard
Jun 14, 2005 09:25 AM
