Starting issues
Old Nov 23, 2012 | 05:49 PM
smokinf1's Avatar
smokinf1
Starting issues
I have an 88 f150 thats been acting up when starting. Sometimes it will crank up no problem, and others it makes about a half second try and then nothing. It always jumps off fine though. Went to advance today and found out the following:
battery test- 12.75v 487 cca
alt test- no load 14.32v loaded 14.24 v
starter test- 8.38v and didnt start
All the cables looked okay. Think it could be the starter?
Old Nov 23, 2012 | 06:08 PM
Volvo92906's Avatar
Volvo92906
Tap the starter next time, or go get it tested.
Could also possibly be the starter solenoid going bad. Seen that before.
Old Nov 24, 2012 | 06:04 PM
smokinf1's Avatar
smokinf1
I tried replacing the starter today and got it hooked up fine and went to crank it up and its just spinning. Its not engaging the motor at all. We compared it to the original starter and it appears identical. The starter was all the way in as far as no flange sticking out. Any thoughts?
Old Nov 24, 2012 | 06:11 PM
Volvo92906's Avatar
Volvo92906
Teeth on the flywheel ok?
Old Nov 24, 2012 | 06:29 PM
smokinf1's Avatar
smokinf1
Yea they didn't look bad, and there haven't been any similar issues with the old starter spinning without catching either. Should I try putting the old one back on now and see if it does the same? Even though it wouldn't consistently start the truck, it might show if the new issue is starter or flywheel.
Old Nov 24, 2012 | 06:32 PM
Volvo92906's Avatar
Volvo92906
I would do that. Maybe even bench test the starter to see how it engages. Some starters can look the same but have a different engaging pawl.
Tyler S
27
Jun 19, 2015 09:09 AM
mOROTBREATH
18
Sep 24, 2013 07:01 PM
America
Aug 28, 2013 11:41 AM
BuckHammer
55
Jan 31, 2011 12:59 AM
thumper869
Oct 27, 2009 01:17 AM
