e4od fluid?
Old Nov 23, 2012 | 10:52 AM
f1501987's Avatar
f1501987
e4od fluid?
What kinda fluid u use in a e4od? Do u use dex 3/5 or what
Old Nov 23, 2012 | 11:11 AM
fordman67's Avatar
fordman67
3 is correct.dont use 5.....of will disolvd the glue on the clutches supposedly
Old Nov 23, 2012 | 12:14 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Maybe this helps you:
https://www.ford-trucks.com/forums/1...ion-fluid.html
Old Nov 23, 2012 | 12:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
MERCON V is the right fluid.
Old Nov 23, 2012 | 02:48 PM
BuckHammer's Avatar
BuckHammer
Yeah, I agree with everything Mark says about Ford automatic transmissions, lol. I believe that MERCON V superseded MERCON as the recommended fluid for the E4OD. I imagine that anything that meets the old MERCON specs would work, too, though. After all, that was the recommended fluid at the time of manufacture.
Old Nov 23, 2012 | 04:14 PM
fordman67's Avatar
fordman67
When did that change? Used to be Ford advised not to put v in place of 3.said it would dissolve the glue in the clutches.I am not dissagreeing just curious and perplexed.
Old Nov 23, 2012 | 04:28 PM
Mark Kovalsky
First, there never was a MERCON 3. There was MERCON and MERCON V. MERCON was the fluid used when the E4OD was manufactured.
Ford NEVER advised that MERCON V would dissolve the glue in the clutches. Some dealer might have told you that, but a dealer is not Ford. The original MERCON V did cause problems in the E4OD, but it did not dissolve the glue in the clutches.
In 2006 Ford discontinued MERCON and reformulated MERCON V to make it compatible with older transmissions that used MERCON. MERCON V is now the right fluid for the E4OD.
Old Nov 23, 2012 | 08:27 PM
f1501987's Avatar
f1501987
Ok thanks any brands yall prefer
Old Nov 23, 2012 | 08:30 PM
fordman67's Avatar
fordman67
Cool.i will let u know i worked as a line rech at ford for 8 years. That is what we were told.i now know better.thanks, i am going to service my trans soon so i will use v on it. See.you learn something every day.even when you are off for holiday.thanks mark!
Old Nov 23, 2012 | 11:15 PM
oldbird1965's Avatar
oldbird1965
I use Shaeffer's all trans fluid. Its used by BTS and John Wood. Racer X recommends red line, I think, but said Shaeffer's is a good choice also.
Old Nov 24, 2012 | 06:55 AM
Mark Kovalsky
Did you work at Ford or at a Ford dealer? There's a BIG difference.
Old Nov 24, 2012 | 12:00 PM
fordpride's Avatar
fordpride
Are you thinking of DexronIII/Mercon?
Old Nov 24, 2012 | 07:45 PM
fordman67's Avatar
fordman67
Ford dealer
Old Nov 24, 2012 | 08:57 PM
BuckHammer's Avatar
BuckHammer
First, there never was a MERCON 3...
I figured that he meant DexIII. The typical, generic "Automatic Transmission Fluid" you see meets DexronIII and MERCON. See below, but pretty much every manufacturer makes it, not just Castrol:
Old Nov 24, 2012 | 10:58 PM
fordman67's Avatar
fordman67
Yep that is what i meant.i got lazy fingers
1992forever
Sep 21, 2010 04:06 PM
93FordCTD
Apr 19, 2010 05:44 PM
danlee
Oct 21, 2009 06:45 AM
00bucker
Feb 22, 2007 07:32 PM
