Need Rear end
Old Nov 21, 2012 | 06:00 PM
imjwm's Avatar
imjwm
Need Rear end
I just broke the rear axle in my 250 and i need to put in a whole new rear end! Need some advice! Has anyone ever put in a one ton or 3/4 hd in? it has a 355 in it now! where is a good place to get one?
Old Nov 21, 2012 | 06:09 PM
DarkStarMedia's Avatar
DarkStarMedia
Where are you?
Richard
Old Nov 21, 2012 | 06:44 PM
stainlessstroker95's Avatar
stainlessstroker95
A 1 ton will have the same rear end as a 3/4. Sterling 10.25
Old Nov 21, 2012 | 06:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you broke a sterling 10.25? can you elaborate? very curious.you sure don't read this often.
as far as buying another srw sterling,they're very common and easy to find.
Car-Part.com--Used Auto Parts Market
tip;
stick with the 2nd gen.don't go any older than '93,and no newer than '97 if you can help it (which shouldn't be a problem.)
score it from an f250hd or f350 srw (pickup only.)
Old Nov 21, 2012 | 07:09 PM
rusty1161's Avatar
rusty1161
I have one out of a 1997 F250HD, but 4.10 gears, limited slip and 212,000 miles. I swapped in a 10.5 in its place. Still has good miles left on it. I am in SoCal.
Rusty
Old Nov 21, 2012 | 07:45 PM
glovemeister's Avatar
glovemeister
Lol I am very curioous how you broke a full float sterling? Those axle shafts are monsters.
Old Nov 21, 2012 | 07:46 PM
6.0techwannabe's Avatar
6.0techwannabe
Were ARE YOU dude? I have two.
Old Nov 21, 2012 | 07:59 PM
96ford250's Avatar
96ford250
I have one too its got 4.11s but you can swap gears
Old Nov 22, 2012 | 08:29 AM
rodneywar's Avatar
rodneywar
he is in ohio based on his info
Old Nov 22, 2012 | 10:15 AM
imjwm's Avatar
imjwm
I am in southeastern OH! It is not a full float sterling! The truck is a 1994.5 f250 4by4 automatic! Can i put a sterling in it?
Old Nov 22, 2012 | 10:46 AM
427 fordman's Avatar
427 fordman
It IS a sterling 10.25.
Old Nov 22, 2012 | 10:57 AM
imjwm's Avatar
imjwm
When i called in to ford with the vin they said it is not a full float!
Old Nov 22, 2012 | 11:01 AM
BuckHammer's Avatar
BuckHammer
You broke the whole housing and everything? How?
Old Nov 22, 2012 | 01:48 PM
farmert's Avatar
farmert
I've never heard of a diesel with out a full floater. If you have a 94.5 with an auto tranny, you must have an IDI, as you could only get an early stroke with a ZF 5 speed manual tranny.
Old Nov 22, 2012 | 03:07 PM
FORDF250HDXLT
whoever looked up your axle info using your vin didn't do a very good job lol.
why are you not telling us what broke?
there's been stories of owners claiming to have the semi floaters in 1983 & 1984 idi diesels,but no hard core evidence that they came that way from ford even at that.since it was the first year or two,it's hard to say.perhaps they didn't think things through at first and or just wanted to use up some old axles,who knows.
one things for sure,gas or diesel,there hasn't even been anyone showing a pic of a light duty 9th gen f250.let alone having a light duty f250 diesel.whoever he talked to over at ford,didn't use his computer correctly lol.
