4r100 question
Old Mar 18, 2011 | 08:15 PM
lincolnboy73's Avatar
lincolnboy73
4r100 question
Hey guys, just wondering if anyone knows if a 2001 Expy with the 4R100 shallow pan (2wd) has a drain plug for the torque converter, and if not, how I go about getting all the fluid out. Thanksssss
Old Mar 20, 2011 | 10:30 AM
Moto Mel's Avatar
Moto Mel
Pull the plastic plug from under the converter and rotate the engine by hand while looking in the hole. Put a mark on the converter before you start so you know when you have gone 360*.
Most just change what is in the pan and the filter and if done regularly that is good enough. If that's not satisfactory you will have to pull the trans and remove the converter to drain it completely.
Old Mar 21, 2011 | 01:13 AM
fixit5561's Avatar
fixit5561
I took my '03 Nav. to the local oil change to have the trans fluid R&R. I used to work at this one so I know how they do it to get it all out of the trans and torque conv.
If you ask them if they do this through the trans cooling lines and they say yes, then they can do it and get it all out for you. I think it was about $80.00 to have it done.
Someone here also posted a method to do it yourself with a buddy using the trans cooling lines where they attach to the trans. Do a search and Im sure it wil come up.
Old Mar 21, 2011 | 08:40 AM
alloro's Avatar
alloro
Try this...
https://www.ford-trucks.com/forums/1...ml#post9788756
azelkster
13
Mar 1, 2016 11:05 AM
Jake Gerrald
Jun 1, 2015 07:06 PM
Bergerson
23
Sep 25, 2014 01:19 PM
andrew240z
Dec 2, 2007 06:43 PM
rsylvstr
Feb 8, 2007 09:22 AM
