glow plugs
Old Nov 22, 2012 | 06:17 PM
barrett74's Avatar
barrett74
glow plugs
I'm new to diesels so need a lil help where r the glow plugs on a 92 7.3 idi non turbo? And what is needed to change them?
Old Nov 22, 2012 | 06:31 PM
Diesel_Brad's Avatar
Diesel_Brad
They thread into the intake, right next the injectors. You will see a single wire going to each one.
As long as the tips are NOT swollen, they just thread right out. When replacing them ONLY use motorcraft ones. ANY other brand will cause serious problems
Old Nov 23, 2012 | 10:39 AM
barrett74's Avatar
barrett74
R they under the valve cover or are they in plain sight?
Old Nov 23, 2012 | 12:10 PM
Phy's Avatar
Phy
They're in plain sight, right next to the injectors, with a wire connected to them.
Old Nov 23, 2012 | 01:13 PM
barrett74's Avatar
barrett74
Ok got em on but the truck is still hesitant to start any pointers on where to look next?
Old Nov 23, 2012 | 01:24 PM
Diesel_Brad
Are you getting power to the Glow plugs? the controller can go bad
Old Nov 23, 2012 | 01:34 PM
barrett74's Avatar
barrett74
I'm not sure. where's controller at?
Old Nov 23, 2012 | 02:23 PM
Diesel_Brad
IIRC on the IDI it is at the back of the intake
But just put a test light on each wire where they go into the glow plug(with the key in the run position)
Old Nov 23, 2012 | 03:33 PM
barrett74's Avatar
barrett74
Ok they all light up but still is startin rough can it be a bad battery?
Old Nov 23, 2012 | 04:56 PM
Roy Wieler's Avatar
Roy Wieler
Glow Plug Test
Check each of the glow plug resistance from its terminal to ground with an ohmmeter--the glow plugs should be less than 2 ohms when cold. Another way to test the glow plugs is with a test light (not a LED/circuit tester). Connect the alligator clip to the positive battery terminal and touch the probe to each (unplugged) glow plug terminal. The test lamp will light brightly if the glow plug is good.
Even one open glow plug can shorten the controller on time sufficiently to affect starting.
Next connect the glow plug harness and check for voltage at the relay "hot" terminal with the key off, then check for a voltage drop at the glow plug terminals (86 and earlier) or at the controller/relay "hot" terminal (87 and up) with the relay energized.
If the voltage is low or drops below 10 volts with the relay energized, check for loose connections at the glow plug relay, starter relay or engine harness connector, or bad fuse link(s). Also check for voltage at each glow plug terminal with the relay energized.
twg1966
Aug 28, 2010 08:12 PM
blueeyedfordguy
General Diesel Discussion
May 4, 2010 09:48 PM
daves96stroke
Feb 24, 2010 09:32 PM
Tim Young
Aug 1, 2009 03:06 PM
basstardo
Oct 21, 2005 03:16 PM
