Rough, Misses, Jumps When Cold
Old Nov 22, 2012 | 05:55 PM
rwthompson's Avatar
rwthompson
My 2004 F-350 with 6.0 Diesel starts up fine with little smoke or chatter. When I start down the highway and the auto transmission shifts through 3rd or 4th the truck starts to miss/jump badly. I coax it along gently for a few miles and after it warms up it does great. What's up?
It has 143,500 miles and has just had the following maintenance by the dealer:
Oil and filter, Fuel Filters, EGR service, tranmission fluid change, transfer case fluid change, differinial fluid change, injectors cleaned, and new batteries.
Old Nov 22, 2012 | 07:32 PM
davbeisner's Avatar
davbeisner
Maybe ipr or ICP sensors?
Old Nov 22, 2012 | 08:49 PM
BLADE35's Avatar
BLADE35
Under those conditions usually Bad Injecttor
Old Nov 22, 2012 | 11:55 PM
04badford's Avatar
04badford
Do you have any Gauges? scan GaugeII will help , Benny Directed me to two sencers= Map connection to the Egr cooler and hose was plugged and Icp . My ICP connection was the problem, But Benny will set you in the right direction . theres alot of great guys here with alot of very good Info.Give them all of the truck running issue(stalling surgeing, color of smoke, cold and hot start,ETC).Happy Thanks giveing to all and good luck
Old Nov 23, 2012 | 09:44 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I wouldn't rule out an STC fitting if this is a late 04 engine.
Josh
Old Nov 23, 2012 | 10:23 AM
rwthompson's Avatar
rwthompson
Thanks to all of you. I will start to run some of these down. By the way what is a Benny?
Old Nov 23, 2012 | 10:48 AM
BLADE35's Avatar
BLADE35
ME!!!!!!!!!!!LOL
Old Nov 23, 2012 | 11:33 AM
Bullitt390's Avatar
Bullitt390
We all wonder what a Benny is... LOL
Josh
Old Nov 23, 2012 | 11:35 AM
BLADE35's Avatar
BLADE35
Josh
Im am Shure my Wife could Clear this Up LOL
Old Nov 23, 2012 | 07:32 PM
04badford's Avatar
04badford
LOL, Sorry Blades ( aka Benny) Im Never mind , Ill be silent now I hope you all had a great dinner.
Old Nov 24, 2012 | 12:05 AM
icemann21's Avatar
icemann21
Just my .02 but I had this happen a while back on my old truck, and the culprit was a bad torque converter. My symptom litteraly made the whole truck jump. I thought it was an engine problem. Couldn't figure it out for a while, and it ended up junking my tranny. Luckily I was never stranded, but still tranny's are not cheap to have rebuilt.
My other idea would probably be an injector issue though.
Tupper2015
Sep 10, 2016 03:27 PM
op1324
Feb 13, 2015 12:20 AM
73stang
May 22, 2011 02:48 PM
brohd13
May 13, 2010 09:56 PM
flip1950
Dec 10, 2008 08:32 PM
