1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2013 terrastar 4x4 specs .... here they are
Old 11-22-2012, 02:49 PM
parkland's Avatar
parkland
parkland is offline
we were talking about it before, so here it is.
{MaxxForce 7} EPA 10, 300 HP @ 2600 RPM, 660 lb-ft Torque @ 1600 RPM, 2800 RPM
Governed Speed, 300 Peak HP (Max)
{Allison 1350_RDS} 4th Generation Controls; Close Ratio, 5-Speed, with Overdrive; with PTO
Provision, Includes Park Pawl, Less Retarder, with 19,500-lb GVW & 30,000-lb GCW Max. on/off
hwy
AXLE, FRONT DRIVING:
{Dana Spicer 70-273} Single Reduction, 8,000-lb Capacity
AXLE, REAR, SINGLE:
{Dana Spicer S110} Single Reduction, With Offset Housing; 13,500-lb Capacity, 160 Wheel Ends
Gear Ratio: 4.30
TRANSFER CASE {Fabco TC-28} Two-Speed, Gear Drive, 3,600 lb-ft Capacity
with Electric Shifting Controls, without PTO Provision
Old 11-22-2012, 03:16 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
You still can't cover up what an ugly duck they are.
Old 11-22-2012, 03:21 PM
parkland's Avatar
parkland
parkland is offline
An XL super duty doesn't look all that cool either, throw a little bling at it
Old 11-25-2012, 05:59 PM
Kahuna's Avatar
Kahuna
Kahuna is offline
What is a Terra Star?
Old 11-25-2012, 06:29 PM
Tom's Avatar
Tom
Tom is offline
http://www.internationaltrucks.com/t...ries/terrastar
It's not a Super Duty, but it's in the same class.
Old 11-25-2012, 11:25 PM
parkland's Avatar
parkland
parkland is offline
Thats a terrastar. They are about the class for an f550 - f650.
Old 11-26-2012, 12:43 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I've seen quite a few of them. I know many EMS agencies are excited, its just what we (they) needed.
Old 11-26-2012, 01:26 AM
parkland's Avatar
parkland
parkland is offline
How come so many guys in the EMS field are obsessed with GIANT trucks?
It seems like there's an anxiousness to prove that the biggest most powerful trucks are needed for this purpose.
Our dep't HAD diesel 450's, now they have chev van chassis gas jobbers, and they work just fine.
Old 11-26-2012, 01:40 AM
AlaskanEx's Avatar
AlaskanEx
AlaskanEx is offline
Bleed Ford Blue
the local fire dept runs 4x4 f-450/550s here for ambulances with nothing but praise.
Old 11-26-2012, 01:55 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
It depends on the dept's needs. My company runs mostly Ford vans, with some new chevy vans because Ford discontinued the Econoline. We also have some ford van modular ambulances, which are the econoline cut-away with a big box on the back.
Our regular vans are for normal use and the modulars are for CCT (Critical care transport), NICU (Neonatal Insensitive Care Unit) and BARI (bariatric... big people) transports. Personally, I love the modulars, there is SO much more room to work on your patient in the back, they ride much nicer (important for your patient too, consider babies or unhealed fractures) and they get the attention of the public much better. Some companies will use the modulars for all calls, not just the special needs ones. Also, I hate the chevys, everything including aftermarket upfitter stuff on them is cheap and sucks.
Some companies/depts use medium duty ambulances. These are usually fire depts who also manage the EMS dept and use the ambulances as rescue units as well. In this case the ambulance not only carries medical equipment, but rescue equipment, too.
The medium duty ambulances also tend to last considerably longer. Initial cost is higher but down time is very expensive in the EMS industry, whether you are talking profit (for-profit companies) or available coverage (govt depts).
Every company/dept has their own reason why they have the rigs they have. I asked the same question once too, and trust me, no dept or company is spending money on an extra large ambulance they dont need.
Here is a standard van ambulance, suitable for most circumstances:
Here is a modular ambulance, they are much nicer to work in IMO some people dont like driving with the extra size:
Here is an ambulance based off of an F-Series truck. This is my preferred set up for several reasons:
And the medium duty, which I have not had experience with, and is least common, especially in heavily populated areas such as the one I work in:
Old 11-26-2012, 02:05 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i found a few shots of ours.
Old 11-26-2012, 02:08 AM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Mmm, beautiful now that Ford has discontinued the Econoline I hope that the depts dont start using chevys, I HATE them with a passion. Everything on them sucks. I'm hoping the industry tries different options and settles on F-Series as the standard.
Old 11-26-2012, 02:13 AM
parkland's Avatar
parkland
parkland is offline
I bet the terrastar would make an awesome emergency vehicle !!!
The 2wd ones are cheap.
I priced them out, 50k - 100k depending on all options.
Old 11-26-2012, 06:45 AM
kd0axs's Avatar
kd0axs
kd0axs is offline
Old 11-26-2012, 09:25 AM
ParamountTrucks's Avatar
ParamountTrucks
ParamountTrucks is offline
The terrastar's suck big time gents. Because they dont want to adopt the DEF system, they run a shyat load of egr through the motors, causing awful fuel mileage.
6.7L Powerstroke FTW!
P.S: They are a light duty truck and are in the F550 class, not a F650.
Quick Reply: 2013 terrastar 4x4 specs .... here they are
