skipping 7.3
Old Nov 21, 2012 | 09:56 PM
79str8six's Avatar
79str8six
skipping 7.3
i have 2003 super duty that is skipping for a fraction of a second like i turn key off fast,sometimes stalling,replaced icp sensor,ipr,there is new fuel filter,cps, wire pigtail for icp. still skipping,help!
Old Nov 24, 2012 | 02:41 PM
DavidE's Avatar
DavidE
Help
Presume you've done searchs first. If not able to resolve with info from them then post more info as to the exact circumstances under which this condition is experienced so gurus can make suggestions. ie Happens when driving at what speeds, only when stopped, when braking or is intermittent or what to say what are the condtions under which you are experiencing this behavior?
Old Nov 24, 2012 | 02:49 PM
1fixitman's Avatar
1fixitman
Normal questions first.
What is your location?
What is your oil level on the dipstick?
how much fuel is in your tank?
How many miles on your truck?
How many miles since you did an oil change?
Are you running a chip or power adder?
Is your truck stock?
Do you have a CEL(check engine light) or SES(service engine soon)
Have you done the 50 cent mod?
If you are running a chip.....can you go back to stock easily to troubleshoot?
Does it only skip at Idle or is it skipping at 70MPH going down the interstate?
Is it skipping at a particular RPM under load or not under load?
If you place it in neutral and raise the throttle from idle does it do it at higher RPM's unloaded from the transmission?
The way your idle works is by resistance of a Throttle Position Sensor(TPS) that sends a signal to the PCM. This resistance is only if the Idle Validation Switch(IVS) is not being contacted by the gas pedal. When you push on the gas pedal and the IVS is no longer making contact then the PCM knows what resistance the TPS is at and as the resistance goes up it changes voltage and voltage goes up and the PCM gets that voltage signal. If the TPS has any dead spots on the resistor then the PCM does not know what to do.
I am just telling you how your gas pedal works to help you. It could be ICP, IPR, TPS/IVS, EBP sensor, We kind of need more information as to wether it is right when the truck starts or does it do it all the time hot or cold engine? How many times does it happen over what period of time? Be diligent and observant.
jstihl
Dec 23, 2017 08:18 PM
plgebbia
Sep 21, 2010 11:06 AM
mhs53
Jun 19, 2007 05:08 PM
Paul1212
Dec 6, 2006 05:58 PM
Turbo_Whistler
Dec 27, 2005 11:18 AM
