Extremely touchy accelerator pedal!!!???
Old Sep 18, 2010 | 01:20 PM
plgebbia's Avatar
plgebbia
Well, I sold my truck, and am now driving the one I got in Dallas.
It has a really touchy pedal from idle to about 1200 rpm. I changed the pedal out for another one I had, no difference. I am thinking that the IPR might need a cleaning, is that a possibility? Any other ideas?
Thanks!
Old Sep 18, 2010 | 04:40 PM
plgebbia's Avatar
plgebbia
Anybody?????
It is a real pain to drive through parking lots and such right now!
Old Sep 18, 2010 | 06:49 PM
Hussler's Avatar
Hussler
Sounds like it has a chip in it?
Is that correct?
Old Sep 18, 2010 | 06:56 PM
Action4478's Avatar
Action4478
From the Diesel mans page :
If the IVS switches on at too high of a TPS voltage, it can cause the truck to buck at low speeds as the IVS cycles on and off as the driver tries to control his speed. The only way to correct this is to first loosen and turn the TPS sensor to reach the lowest possible voltage reading on the scan tool and retighten. Then bend the IVS stop to adjust the on/off point to 0.2-0.3 volts above the base AP voltage reading. Note: There have been cases of lack of throttle response and the above codes which were caused by the PCM not recognizing the IVS "on" signal. Replacing the PCM corrected the problem.
Old Sep 19, 2010 | 06:50 PM
plgebbia's Avatar
plgebbia
Thanks for the replies,
The truck is not chipped. Unless there was a programmer on it before that I do not know about.
Since I changed the whole pedal out (IVS,TPS and all) it can't be that right?
Is it possible that a faulty/dirty IPR could cause this?
Is there a way to find out if there is a programmer on it without having it reflashed?
Sorry for all the questions,
Thank you!
Old Sep 20, 2010 | 10:12 AM
plgebbia's Avatar
plgebbia
Anybody???
Old Sep 20, 2010 | 11:04 AM
Brown Falcon's Avatar
Brown Falcon
If it was programmed you have to have it reflashed.
Sorry, don't know much about this problem...
Old Sep 21, 2010 | 09:31 AM
plgebbia's Avatar
plgebbia
Any thoughts???
Old Sep 21, 2010 | 10:01 AM
mueckster's Avatar
mueckster
Does it idle smooth? Have you looked at the ICP sensor for a 10k mod?
Old Sep 21, 2010 | 11:06 AM
plgebbia's Avatar
plgebbia
Thaks for the reply,
Yes, it does idle smooth, and there is no 10k mod.
It also seems to be getting a little better the more I drive it?
ClaytonCardone
Oct 20, 2016 12:15 PM
flagator
Nov 25, 2015 07:35 AM
sailmfast
6.4L Power Stroke Diesel
Jun 8, 2015 09:57 PM
mrjc
6.7L Power Stroke Diesel
Sep 25, 2012 10:59 PM
1.3mazda
1983 - 2012 Ranger & B-Series
May 1, 2009 09:44 PM
