Horn Pad
Old Oct 7, 2016 | 09:00 PM
76F150explorer's Avatar
76F150explorer
Originally Posted by mikeo0o0o0
Dennis Carpenter has them.
Dennis Carpenter Ford Car, F-100 Pickup Truck, 8N, 9N Tractor and Cushman Scooter Restoration Parts
EDIT: I take that back. Apparently DC doesn't have them anymore. I checked the website and its no longer listed, same thing with LMC. NPD still lists it but its out of stock.
Thanks Mike for the p/n that's a step in the right direction at least.
I looked up the P/N, you need D5TZ-13A805-B
That's the horn bar with cruise and burl walnut trim.
Unfortunately, no dealer or obsolete parts supplier has one.
Old Oct 7, 2016 | 09:02 PM
76F150explorer
Originally Posted by ubereal2
My buddy Rich (77and79F250) sent you a PM, and I'm sure he can get you going. If he doesn't have one for you, I have a good horn button for a factory steering wheel in the shed.
Just let me know.
Unk Bob
Thanks, I haven't got the pm yet. I appreciate it. Is the one you have with speed control or not?
Mine has the factory speed control but the plastic backing that holds everything together is starting to crumble
Old Oct 8, 2016 | 12:04 AM
AK FORD GUY's Avatar
AK FORD GUY
Just let me know.
Unk Bob
This is a resurrected thread from 2012, Rich sent the PM to the op.
None the less, he may still be able to help him out.
Old Oct 8, 2016 | 06:01 AM
ubereal2's Avatar
ubereal2
Wow, I sure missed that one by a few years.
My horn pad is wood grain, but no cruise.
Unk Bob
Old Oct 8, 2016 | 06:57 AM
Damifiknow's Avatar
Damifiknow
I find good parts using these search engines.
Car-Part.com--Used Auto Parts Market
Used Auto Parts | Used Car Parts | Auto Salvage
Old Oct 8, 2016 | 02:12 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 76F150explorer
Any idea where to find a replacement horn bar with factory speed control?
1975/77 or 1978/79?
Old Oct 8, 2016 | 08:59 PM
76F150explorer
1975/77 or 1978/79?
Mine is a 1976 F150
Old Oct 9, 2016 | 09:59 AM
NumberDummy
Mine is a 1976 F150
D5TZ-13A805-B (replaced D5TZ-13A805-A) .. Horn Pad & Switch-Use with factory installed Speed Control / Obsolete
1975/77 F100/350 & Econoline.
No Ford dealer or obsolete parts vendor has any.
Old May 20, 2021 | 04:07 PM
zjd's Avatar
zjd
D5TZ-13A805-A (Bronco) for 77 Truck?
I saw this D5TZ-13A805-A in the discussion but classicautparts.com lists that as being for Bronco and incompatible with the Truck. It looks exactly right, though. Anybody have experience using one of these? LMC and Jeff's Bronco Graveyard both have the D3TZ-13A805-A (no speed control) and it shows up for both Bronco and Truck. That makes me suspect it would work. I'm trying to replace my horn bar (77 with speed control).
https://classicautoparts.com/horn-pad-2384
Old Aug 18, 2025 | 08:52 AM
egchewy's Avatar
egchewy
resurrecting this old thread
1979 F150 w/ cruise.
Original dash pad is crumbling to dust.
It appears that a replacement pad w/ cruise buttons is obsolete.
Has anyone devised another way to hook up a cruise switch? Aftermarket steering wheel w/ a home brewed solution? Relocating a switch to another part of the car?
Old Aug 18, 2025 | 10:09 AM
Rubiranch's Avatar
Rubiranch
I bought a new one from GPD, General Parts Depot.
It was made by Dennis Carpenter but they were out of stock.
They must have sold them all to GPD.
Old Aug 18, 2025 | 10:43 AM
egchewy's Avatar
egchewy
Thanks but looking for the pad w/ cruise control buttons.
Old Aug 18, 2025 | 12:03 PM
  #28
tbear853's Avatar
tbear853
Mine is an add on cruise made by Dana for Sears, etc back in the day. From what I've seen, I think maybe was same as Ford used. I've had mine in my '77 since the mid '80s, before that I used a same kit to add to a couple cars. It works. I didn't want turn signal switching on my truck, so I used a couple momentary contact button switches and a toggle switch in a housing I formed, but they included a plastic stick on dash option. 4 small diameter wires are involved, I used switches from Radio Shack.
Set / Coast is
yellow .... Resume / Accelerate is green .... and are just touched momentarily to ground brown to work with the buttons.
On / Off
is red to power using the switch.
I do not know Fords colors, etc but might be able to trace back down through the columns harness to find out, or maybe is a chart for factory cruise you can find?
Mine is a '77. This below is from the still "new in box" kit I bought a few years ago off ebay to have spare parts.
Philo Beddoe
May 25, 2010 11:42 AM
panochote
1997 - 2003 F150
Sep 21, 2007 10:30 AM
StephenA
Nov 5, 2005 10:45 PM
