2004 explorer misfire
Old Nov 21, 2012 | 05:44 PM
valcwby81's Avatar
valcwby81
my 04 exploder is showing 0300, 0316, 0402. replaced plugs, wires, plenum gasket. what is my next move. sorry for my format, typing on cell phone while in a moving ambulance.
Old Nov 21, 2012 | 06:01 PM
yorky's Avatar
yorky
for those who wish to know what the codes are,
p0300 random-multiple misfire detected
p0316 misfire detected on startup (first 1k revs)
p0402 Exhaust gas recirculation flow excessive detected
Old Nov 21, 2012 | 06:44 PM
valcwby81's Avatar
valcwby81
also, compression for cylinder 5 is good
Old Nov 21, 2012 | 10:09 PM
steve(ill)'s Avatar
steve(ill)
random missfire normally means multiple cylinders. So something they have in common. I assume you have 1 or 2 coils for multilple cylinders ? ONe may be weak.
Old Nov 21, 2012 | 11:17 PM
shorod's Avatar
shorod
I'd start by looking in to the source of the P0402. Fixing that could fix the random misfire codes.
Per the factory service manual, the following are likely causes of the P0402 diagnostic code:
  • EGR valve stuck open
  • Plugged EGR vacuum regulator solenoid vent
  • Plugged EGR tube
  • Slow responding D.P.F. EGR sensor
  • Damaged DPF EGR sensor
  • Improper vacuum hose connection
  • Plugged vacuum hoses
  • EGRVR circuit shorted to ground
  • Damaged EGR vacuum regulator solenoid
  • Damaged PCM
Keep in mind that the DPFE sensors have been common issues on several models of Fords. Also keep in mind that, depending on which engine your Explorer has, intake manifold gaskets have also been a common issue and could explain random misfires.
-Rod
Old Nov 22, 2012 | 02:46 PM
valcwby81's Avatar
valcwby81
is the dpfe sensor IN the egr?
Old Nov 22, 2012 | 03:26 PM
yorky's Avatar
yorky
the dpfe (differential pressure feedback snsr). is not inside the egr. I'm don't know your layout but it should be on the LH front side on engine possible on the air intake with 2 hoses connected to it. It will be about a inch wide by about 2 inches long and 1/4 in thick beinging held by 2 bolts, one on ither side. The link will take you to pictures of 2 different setups for it (side and bottom ports).
https://www.google.com/search?q=2004...&ved=0CLQBELMY
twilson1020
Aug 17, 2015 10:15 PM
bigdan1979f-250
Feb 25, 2013 12:09 PM
98explorer311
Jan 14, 2004 09:17 AM
scottsride
Mar 16, 2002 08:20 PM
