Fuel Injector Cleaner?
Old May 22, 2003 | 02:59 PM
Hit Man X's Avatar
Hit Man X
I am wondering where I could find a GOOD injector cleaner. Made by 3M or someone like that. None of that pour intank stuff.
If you can point me in the correct direction that would be great!
Thanks!
Old May 22, 2003 | 03:21 PM
billman's Avatar
billman
Here's one off the net
Old May 22, 2003 | 03:35 PM
Hit Man X's Avatar
Hit Man X
I can't tell by those pics but...are those the type that you screw into that schrader valve on the fuel rail?
Old May 22, 2003 | 07:25 PM
billman's Avatar
billman
It is intended by these 3M kits to attach to the fuel rail. You would have to contact 3M directly for a specific application.
Here is a plethora of 3M products. Actually, in a part of their website, you can order some items (plus tax) free of shipping for the same price as your local retailer. I buy their TB spray direct.
Old May 22, 2003 | 07:36 PM
Hit Man X's Avatar
Hit Man X
That is what I needed to know, thanks!
Old May 22, 2003 | 09:42 PM
johnsonmtz's Avatar
johnsonmtz
From the pictures, it appears the part # 8958 is the one that attaches to the schrader valve. #8957 and it's attachment kit simply require you to remove the vacuum line that is on the fuel pressure regulator and then connect the can of cleaner to that.
Be careful though, none of these systems cleans the throttle body! AFAIK, the only way to clean that is removal and manually doing it.
KJ
Old May 22, 2003 | 11:07 PM
bigbluetruck's Avatar
bigbluetruck
You are right, most of those pour in fuel injection cleaners only clean out your wallet. They really don't do much. If you want something that does clean and dispurse water well that is much cheaper, use 100 octane aircraft fuel. I get it from our local airport and run it in stuff I plan to store. It will work wonders on an old lawn mower that has a gummy carb. It has a different formula than automotive gasoline, it had cleaners added to it so it will disolve varnished gas. The fuel injection cleaners you buy at the parts store is mostly alchohol. The only thing I know that works better is the product that injects into the fuel rail via the shrader valve on the rail. I know of some garages that use it.
Old May 23, 2003 | 12:13 AM
rghutt's Avatar
rghutt
On my 1987 F-150 6 cyl. I once had a procedure done in the shop where they ran a can of solvent through the injectors with some special rig. Whatever it was, it cost me about $90, and made a noticable difference in performance, for the better, although not solving the persistent bad idle in the warm up phase. Did they call it motor vacuuming or something? I wonder if they used a product similar to the one mentioned earlier in this threadd?
Old Jun 7, 2003 | 03:44 PM
TimH's Avatar
TimH
Has anybody ever tried that BG fuel injector service you see advertised on TV? I have a rough idle any my garg guy sugested having it done. Of course he just ahppens to do this service also.
Old Jun 8, 2003 | 10:00 PM
BBiffle's Avatar
BBiffle
Techron is a good pour in tank.
Old Jun 9, 2003 | 01:49 PM
92Pony's Avatar
92Pony
Yep - Chevron with Techron is the only pour-in that I've had positive results with. STP and the like are a waste of money.
Wade
Old Jun 9, 2003 | 02:00 PM
Carbine's Avatar
Carbine
Sea Foam or Red Line
http://www.seafoamsales.com/
Old Jun 10, 2003 | 07:47 PM
Phobia16V's Avatar
Phobia16V
The full service usually isn't necessary. BG 44K (which is a pour-in-tank product) has worked very well for me in every vehicle I have owned. It's pricey(~$20 can) but it is well worth the price.
1L243
15
May 10, 2014 12:55 PM
Qwatali Hunter
Mar 14, 2011 09:38 PM
GBURKS
Nov 21, 2010 11:31 PM
Jsolo1985
Oct 7, 2010 10:19 AM
erndog
Sep 13, 2005 07:26 AM
