having starter trouble 85
Old Jul 8, 2009 | 09:15 PM
QH rancher's Avatar
QH rancher
I am having trouble with an 85 3/4ton 4x4 460 auto starting after it gets a little warm, it wont turn over much i changed the starter and put a high cranking battery in it still no help. i am wondering if the cables mite be week i messed with the timing and it helped a little. Any advice would be appreciated thanks.
Old Jul 8, 2009 | 09:33 PM
Franklin2's Avatar
Franklin2
Do you have headers? If so, wrap the starter with something to shield it. If turning the timing bacl helped, try a little bit more and or make sure the start/retard feature is hooked up on your duraspark II ignition box, if that's what you are running.
