what pertronix system
Old May 22, 2003 | 02:28 PM
robertskunfused's Avatar
robertskunfused
i was thinking of getting one to install my old 360, work truck. Should i go with the ignitor or ignitor ll and which should I order: The one for most 57-74 V8's or the one for 60-72 Dual point w/o vacuum advance. the distributor is stock, so i was thinking the first one but i wanted to be sure. any help would be great.
Old May 22, 2003 | 08:56 PM
baddad457's Avatar
baddad457
I've run both and can't tell you the difference between the two. Get the cheaper one and order for a single point distributor, I doubt you have a dual point. Those were mostly used on the Hi-po motors. You also need to get the coil that goes with it and unless your wires are fairly new, it would be a good time to upgrade them as well.
natira121
Mar 15, 2010 05:56 PM
1972-34ton
Jul 27, 2009 10:47 PM
pramos
Feb 25, 2003 11:27 AM
Mistro
Oct 24, 2002 08:34 PM
otto
Feb 12, 2001 09:33 PM
