Map sensor location.
Old Nov 21, 2012 | 05:32 AM
Jhouse85's Avatar
Jhouse85
Hello, I have a 96 f250 7.5l with the stock cali Maf sequential fuel injection. Do I have a MAP sensor and where is it located? Could somebody link me a photograph. I can't seem to find it in my chiltons manual as it doesn't seem to show the 96 cali emissions model.
Old Nov 21, 2012 | 06:42 AM
DIYiT's Avatar
DIYiT
If it's a MAF vehicle, you don't have a MAP sensor.
Old Nov 21, 2012 | 07:59 AM
rla2005's Avatar
rla2005
Your Cali. emission truck is not very common. Very few manuals, if any, will have information for your specific model/engine/MAF combination. Why are you trying to find a MAP sensor?
Old Nov 21, 2012 | 11:25 AM
Jhouse85's Avatar
Jhouse85
Thank you I had a feeling because it had a MAF it wouldn't have a MAP. Just wanted to ask because I have had vehicles in the past that had both.
The reason I was looking for it was I have been running lean and pinging at part throttle, even after replacing all the broken vacuum lines. I'm certain there is still a vacuum leak somewhere.
Do the throttle body/intake gaskets ever leak as they get older?
Also should the EGR on my vehicle hold vacuum? whenever I hook up my vacuum pump it works (stalls the vehicle/drastically lowers idle speed) but it won't hold vacuum for more than 3 secs.
It seems to only ping once the engine is fully warm. It runs great until its warmed up, then it starts pinging like mad at part throttle.
Old Nov 21, 2012 | 11:50 AM
DIYiT's Avatar
DIYiT
I don't know if it's common, but my 135,000+ mile truck has a lower intake manifold gasket leak.
Old Nov 21, 2012 | 12:04 PM
Jhouse85's Avatar
Jhouse85
Well I'm at 150k+ so I'll check mine out.
Old Nov 21, 2012 | 02:27 PM
rla2005's Avatar
rla2005
IIRC the EGR should hold a vacuum for longer than 3 seconds. Sounds like a punctured diaphragm to me. This is assuming you are applying vacuum directly to the EGR.
Yes the intake/throttlebody gaskets can crack due to age, heat, etc.
Old Nov 21, 2012 | 03:40 PM
Jhouse85's Avatar
Jhouse85
I thought it should hold vacuum for more than 3 seconds, and yes this was when I directly hooked up to the egr. Is it possible to just replace the diaphram or do I possibly need a new egr valve?
Old Nov 21, 2012 | 05:05 PM
rla2005's Avatar
rla2005
I have never investigated the possibility of just replacing a diaphragm. I have always replaced the entire assembly.
Old Nov 21, 2012 | 05:42 PM
Jhouse85's Avatar
Jhouse85
Well I rechecked my egr valve and it actually does hold vacuum, I don't know how I messed that up *shrug*.
I also checked my initial timing which is supposed to be 10 and at a certain angle it looked 10 but another angle it looked to be about 12-13. so what angle should I be looking at it from? Sorry if that sounds dumb.
Old Nov 21, 2012 | 10:42 PM
rla2005's Avatar
rla2005
Fuel Injection Technical Library » Setting the timing
Old Nov 22, 2012 | 02:42 AM
Jhouse85's Avatar
Jhouse85
Thank you again,
gman97005
Jun 23, 2013 08:01 PM
panici33
Oct 5, 2010 07:35 PM
technomon
Mar 3, 2010 10:43 AM
captntim
Feb 22, 2004 09:46 AM
gdoggy
1983 - 2012 Ranger & B-Series
Jul 29, 2003 09:36 AM
