Misaligned bed (supercrew)
Old Nov 22, 2012 | 12:53 PM
ecoboostguy's Avatar
ecoboostguy
Yeah well you discover new things everyday. Do you people think that I can just loosen the bolts and just adjust the bed forward a little bit so both gaps be the same?
Old Nov 22, 2012 | 01:04 PM
Papa Tiger's Avatar
Papa Tiger
Could crawl under thar with a bright light and a pry bar, looking for a buckle in the frame and pry lightly on the under side near the mount. Possibly loose or broken? Same in the front behind the motor mounts/frame area. If nothing loosen them and see if you can even the box by nudge. Same around the EPAS, possibly mounting capscrews bent? Watch the epas left to right, right to left looking for misalignment. Measure the clearance to the ground of the tie rod ends. Then it is a body shop visit? It's not your fault, adrenalin did it. I saw Cops bend plymouth steer gear input shafts when in/on the hunt.
Old Nov 22, 2012 | 02:25 PM
juneau76's Avatar
juneau76
I get that illusion on mine depending on how level its sitting. It's never been drastic and doesn't bother me, so I've never measured it. Good luck if you take it in to get it corrected.
Old Nov 22, 2012 | 08:15 PM
TheStuffz's Avatar
TheStuffz
lol great. now im gonna be out with a ruler looking at all the measurements to see how symmetrical my truck really is :P
Stretchmobile
Nov 22, 2016 05:31 PM
Texasknowhow
37
Jan 19, 2015 10:29 AM
1978fordf250
Apr 27, 2005 05:21 AM
galaxiefiveohoh
Oct 29, 2002 11:05 PM
Ron G.
Dec 6, 1999 05:48 PM
