Oil pan replacement?!?
Old Nov 20, 2012 | 10:43 AM
SMS888's Avatar
SMS888
96 7.3l E4od 4x4. Doing an oil pan replacement and I'm getting stuck. I have done some research before I started and have been told that I don't need to remove the engine or turbo or tranny, just jack up the motor off the crank pulley after removing the motor mount nuts and there should be enough clearance. There isn't... The turbo hits the firewall, the pan hits the flexplate, I'm lost. Before I try to pull the turbo or separate the tranny, any ideas? I'd rather not pull the motor if possible and I can't get enough clearance to unbolt the oil screen.
Old Nov 20, 2012 | 11:08 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Either pull the motor or cut the cross member out of the way.
Unless you are a hard-core fabricator with mad welding skills, the motor must come out.
Edit: I have also heard that you can pull turbo and unbolt the body and jack it up out of the way.
But by god, if you are going that far just spend the 3 or 4 hrs and put the motor on a stand. You'll do a much better job replacing the pan and getting it to seal.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Nov 20, 2012 | 02:36 PM
Awitte58's Avatar
Awitte58
^^^x2 pull the engine.
while its out you may wanna clean it up and replace a lot of o-rings.
Wish I would have done that when my engine was out..Really annoying putting it back in and having fuel/oil leaks.
Mich6.0
May 1, 2019 02:09 AM
sparkydmoney
Jun 3, 2018 08:20 PM
Lineman85
Oct 10, 2012 12:32 PM
old-rodder
Oct 26, 2011 02:52 PM
old-rodder
Oct 26, 2011 02:14 PM
