Clunk
Old Nov 20, 2012 | 08:26 AM
zak8tac's Avatar
zak8tac
Clunk
When I'm taking off i've got a big clunk, from coasting to power i get a big clunk. WTF? I've got a fresh transmission in there, brand new clutch and resurfaced flywheel. New u-joints on both intermediate and rear shaft, intermediate shaft is freshly rebuilt with new caps. T-case bushing just replaced. I can't "feel" the clunk the the shifter of the transmission or t-case, but it certainly sounds like its coming from up near the bellhousing. I'm going to pull the inspection cover off and ensure the clutch bolts are still tight to the flywheel tonight. I do not see any indications anywhere about drivetrain parts moving. Any of you gents got any ideas?
Old Nov 20, 2012 | 09:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Transfer case mounts to frame rail using four rubber "donut" shaped insulators. Are they in place, or have they flattened out, or has one or all disintigrated and gone bye bye?
Old Nov 20, 2012 | 09:52 AM
zak8tac's Avatar
zak8tac
Brand new polyurethane t-case bushings (square lower and donut upper) from jbg.
Old Nov 20, 2012 | 10:51 AM
northerndave's Avatar
northerndave
pinion nut loose?
Old Nov 20, 2012 | 10:52 AM
northerndave
Number dummy's idea was my first thought as well. My 1970 F250 has that exact problem.
Old Nov 20, 2012 | 10:55 AM
zak8tac's Avatar
zak8tac
I checked them all and they were nice and tight, good suggestion though I will double check. The clunk seems to be coming from up in the bellhousing though when I hear it in the truck.
Old Nov 20, 2012 | 01:37 PM
bigdan1979f-250's Avatar
bigdan1979f-250
What about where the transfer case sits on the crossmember? Are all of those bolts tight? Try moving your rear driveshaft side to side and also rotate it. If there is any play you might have a bad bearing in the back of your T-case or play in your pinion.
Old Nov 20, 2012 | 04:45 PM
zak8tac's Avatar
zak8tac
No play back and forth but that may be due to the seal around the yoke. I am pulling the rear driveshaft to have that rebuilt and balanced, and I am going to get the t-case rebuilt as well... sure beats something locking up at 60 mph
Old Nov 20, 2012 | 06:52 PM
xkpsanit's Avatar
xkpsanit
Bad motor mount or nut missing on left frame horn???
Old Nov 20, 2012 | 07:05 PM
zak8tac's Avatar
zak8tac
So found my problems... driveshaft needs rebuilt, caps are loose. Additionally apparently one of the u joint I put in a couple years ago was defective. Two of the caps weren't receiving any grease and there were zero, I mean zero needle bearings left, the other two were still in good shape except for some minor indication of over tightening (oops). Glad the old girl likes me and let me hear it before the shaft let go completely. The cross member bolts for the tranny were also a little loose due to the recent transmission replacement and in need of retorquing. Such a close call
Old Nov 21, 2012 | 06:09 PM
tbear853's Avatar
tbear853
Originally Posted by zak8tac
When I'm taking off i've got a big clunk, from coasting to power i get a big clunk. WTF? I've got a fresh transmission in there, brand new clutch and resurfaced flywheel. New u-joints on both intermediate and rear shaft, ... etc ... Any of you gents got any ideas?
It reads to me an aweful lot like a wore out U-joint? I'ld check them "new" U-joints again.
Old Nov 21, 2012 | 09:42 PM
4x4 Bart's Avatar
4x4 Bart
Any grease with Moly in it will eat needle bearings and turn them to dust.
Never use Moly grease in U-joints.
f1001969mike
1978 - 1996 Big Bronco
16
Feb 21, 2013 11:59 PM
FLN
Aug 27, 2008 09:30 AM
DeathMobile
15
Apr 9, 2003 10:23 PM
Greywolf
Feb 19, 2002 10:36 PM
