clutch chatter
Old Aug 25, 2008 | 06:55 AM
FLN's Avatar
FLN
clutch chatter
installed a rebuilt clutch from local auto parts store about 1 year ago.the problem is heavey chatter in reverse.yes i did have the flywheel turned. no problems going forward.i also have new motor mounts & trans mount.so bad at times cant even back up. any suggestions? z bar has new bushings & seals also. the truck is a 68 with 390.thanks for the help!
Old Aug 25, 2008 | 11:16 AM
Danger_Dave's Avatar
Danger_Dave
sounds like a tranny or driveshaft issue to me
Old Aug 25, 2008 | 03:09 PM
Freightrain's Avatar
Freightrain
I had similar issue with new clutch(even though everything was done right). I ended up pulling it out and replacing it with a new one from different manufacture. Didn't re-turn flywheel or anything, unbolt old-bolt up new and it was smooth as glass(to this day).
Old Aug 27, 2008 | 09:30 AM
Red69's Avatar
Red69
ditto.....I had this problem with a remaned clutch. I took the pressure plate to a driveline place and they set it up(adjusted) correctly. No more trouble.
Sous
277
Jul 12, 2017 08:12 AM
lalberts
Dec 4, 2016 10:34 PM
F350AgInspector
Escape & Escape Hybrid
Jan 16, 2012 06:01 AM
Argess
Apr 20, 2011 01:35 PM
andym
Nov 19, 2003 04:02 PM
