Replacement Dipstick tubes
Old Jun 5, 2017 | 10:12 AM
shehan's Avatar
shehan
hi folks... sorry to bring back an old thread but I'm using the search feature as i find myself in a similar situation.
I have a 1974 2wd f100 300ci that needs a dipstick. The PO decided to put a screw in the dipstick tube -- who knows what happened to the dipstick!
numberdummy - i tried to PM you but the system wont let me send you one. the magic you worked above for the 4x4 300ci -- do you see anything for a 2wd?
anyone reading this thread have a lead on a dipstick for a 1974 2wd f100 300ci? I'll buy the tube as well if needed!
thank you
John
Old Jun 5, 2017 | 12:35 PM
The Frenchtown Flyer's Avatar
Can't help with a specific part, but in the past I have used a piece of 3/8 fuel line with a flared nut fitting that screwed right in, cut to about 3" length. I calibrated a blank stick by the 'add oil' method. Or, you can reverse engineer the tube length to match your existing stick if you have one. Good luck.
Old Nov 16, 2017 | 12:36 PM
jobbyjim's Avatar
jobbyjim
need dipstick tube
D7TZ-6750-D .. 300 I-6 Engine Oil Dipstick / Stamped: D7TE-6750-DA / Obsolete
Applications: 1977 F150/250 4WD from serial number O20,000 / 1978/79 F150/250 4WD / 1979 F350 4WD.
YADKIN VALLEY MOTOR CO. in North Wilkesboro NC has 1 = 336-838-4155.
CARPENTER NOS PARTS in Concord NC has 1 = 800-476-9653.
GREEN SALES CO. in Cincinnati OH has 4 = 800-543-4959.
Kinda at my wits end. I am the original owner of a 1979 F150 4X4 with the 4.9L 300CI six. I have a bad oil leak at the dipstick tube. I have tried to seal it with black RTV to no avail. I have been checking for 2 months trying to locate another tube but no luck. You seem to be the master and determining if any new OEM parts exist anywhere and I was wondering if you could do that for me?
Thank you.
Old Nov 16, 2017 | 01:11 PM
shehan's Avatar
shehan
Thank you.
Hey Jobby -- i am 99% sure i've got one. I pulled a 300CI out of my '79 f150 4x4 and am swapping in a 460. I'm only 1% not sure because i just have to see where i placed it. I wont be out to the shop until 11/26, so if you can hold for just a bit longer we can iron it out.
send me a pm so i dont forget
Old Nov 16, 2017 | 01:20 PM
jobbyjim's Avatar
jobbyjim
That will work for me and I will email you on the 25th.
Many thanks!
Old Nov 25, 2017 | 07:18 AM
jobbyjim's Avatar
jobbyjim
Just following up today as you said to check back on the 25th. Sure appreciate anything you can come up with.
Old Nov 28, 2017 | 02:13 PM
shehan's Avatar
shehan
i checked over the weekend and found that a buddy had already removed it.
really sorry!!
Old Nov 28, 2017 | 02:50 PM
jobbyjim's Avatar
jobbyjim
1979 F150 4.9L dipstick tube replacement
Thanks for checking...if anyone else has any recommendations please let me know.
Old Nov 29, 2017 | 09:01 AM
1986F150six's Avatar
1986F150six
I am not certain if you are looking for the "tube" or the dip stick, but NumberDummy posted D7TZ-6750-D and there is one currently listed on eBay: https://www.ebay.com/itm/NOS-1977-19...-/362052997180
Old Nov 29, 2017 | 09:51 AM
jobbyjim's Avatar
jobbyjim
Yes I saw that but I need the tube only. I even asked the seller if by chance he had the tube to go along with the dipstick but struck out. Thanks for checking for me anyways.
choppermanjapan
13
Mar 20, 2016 09:36 PM
460towrig
Dec 11, 2015 11:01 AM
LARIAT 85
Apr 30, 2010 11:37 AM
wmiller
May 23, 2008 10:01 AM
79f100six
Apr 16, 2008 07:55 PM
