Starter Selenoid Wiring
Old Nov 19, 2012 | 06:35 PM
rwkinch's Avatar
rwkinch
I have a 1965 F250 4x4 352 engine.. The truck was running when I got it. I am putting it back together after a few years of body work etc. I took an extensive amount of pictures prior to disasssembly. I am in the process of wiring in the starter selenoid. Looking at the pictures of the way it was wired previously ... is confusing me. I think it was wired backwards. I think the battery was connected to the starter post and the starter was connected to the battery post. Here is a picture. The red battery cable is heading towards the drivers side of the truck because they had the battery cut into the drivers inner fender ( since removed and restored). Please help!![/IMG]
Old Nov 19, 2012 | 07:51 PM
P38fighter's Avatar
P38fighter
Here's how mine looks You seem to be okay
Old Nov 19, 2012 | 10:19 PM
Shadowrider123's Avatar
Shadowrider123
Here is a diagram for teh 3g install I did, its basically the same.
The battery and alternator wire connects to the s terminal, the starter connects to the i terminal.
Old Nov 20, 2012 | 08:02 AM
rwkinch's Avatar
rwkinch
Shadow...that diagram and most printed literature shows it the way it is in that drawing...and that is opposite..Thats whats confusing me..
Old Nov 20, 2012 | 01:13 PM
Shadowrider123
Mine is wired like the diagram and works perfectly.
Old Nov 20, 2012 | 08:09 PM
Becky_is_a_66's Avatar
Becky_is_a_66
It does not matter whether the starter cable is on the left or right big post of the solenoid despite any label that may be on your particular brand of solenoid. Current only flows from one large post to the other large post when the ignition switch is in the start position. Starter cable to one large post; alternator, + battery lead, accesories to the other.
Old Nov 20, 2012 | 08:12 PM
rwkinch's Avatar
rwkinch
Thank You guys!!!
Old Nov 21, 2012 | 09:56 AM
daveengelson's Avatar
daveengelson
Does the truck have an alt gauge; if so, there are a couple variations for that particular circuit?
Old Nov 21, 2012 | 08:36 PM
rwkinch's Avatar
rwkinch
Dave,
Truck does have an alt guage...can you please explain in detail...as I am not well versed in this..thanks! Roger
Old Nov 24, 2012 | 12:33 PM
daveengelson
Sorry, not an authority on auto electrical issues, came aware of the variations to the Amp meter circuit when I decided to add the gauge to my 65. Not clear to me where the wires in your pic's are connected. As I mentioned, there are a couple different examples in the Ford pickup electrical manual, I went with a variation to those. Word of caution, make sure do some research, don't want to experience an elecrical fire.
** Posting couple links as example from the 65 F100-F700 elecrical manual, I do not know if simular/same to the 4X4. http://i300http://.photobucket.com/albums/nn25/...gncharge-2.jpg
http://i300.photobucket.com/albums/n...Diag0001-1.jpg
http://i300.photobucket.com/albums/n...reDiagP5-1.jpg
** This is a copy of the circuit I am running.
http://i300.photobucket.com/albums/n...os/Scan1-1.jpg
http://i300.photobucket.com/albums/n...IMG_0164-1.jpg
http://i300.photobucket.com/albums/n...IMG_0002-4.jpg
Old Nov 24, 2012 | 03:07 PM
rwkinch's Avatar
rwkinch
Dave,
What a beautiful source of information you have shared with me!!.. I am going to study this , but I am pretty sure that I am going to rewire the truck the exact way I took it apart..and i believe It is pictured in one of your diagrams.. Everything worked on the truck.. Lastly..where did you find those plug wire seperators?.. what a nice clean power plant!! Thanks again for helping me!
Old Nov 24, 2012 | 03:34 PM
daveengelson
Happen to have a bench buffer and the 'bling' are used components purchased off ebay. Bought the plug separators many many yrs. ago from Summit Racing, have seen them cheaper, might want to check ebay, or amazon? They also come with just the separators without the piece that attaches to the V cover. Hopefully the pic's will be of some help. Apprciate comments!!
Gigemags05
34
May 8, 2018 11:31 PM
rwriccitelli
Nov 19, 2015 12:22 PM
Bob_Smith
Jun 12, 2012 09:14 PM
stangfan78
Electrical Systems/Wiring
Nov 5, 2007 07:49 AM
85BigBlock
Apr 4, 2005 08:13 PM
