Trans. Seal
Old Nov 18, 2012 | 11:35 PM
Gertie-The '49 F2's Avatar
Gertie-The '49 F2
Trans. Seal
Got a question for the parts gurus here. Perhaps numberdummy will pipe up on this one.
The transmission in question is a 1949 heavy-duty 3-speed in an F-2. What I need to know, is the part number for the rear seal, and any numbers for obtainable equivalents.
Thanks in advance!
J.D.
Old Nov 18, 2012 | 11:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You really ought to get the Parts Manual on CD, they are cheap and are a great resource. Best $20 you'll ever spend.
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
Here's the info you need; as I recall these are available at NAPA under the National Seal number
Old Nov 19, 2012 | 12:20 AM
Gertie-The '49 F2
I know Ross, I should get the manual. But I keep thinking about the parts that money could buy, and that I can always get FREE parts look-ups here.http://images.ford-trucks.com/forums...es/biggrin.gif
Seriously, thanks for the number. Been thinking about the manual for awhile, but I've spent so much this summer for all the parts I have already dumped into Gertie, that I really can't spring at the moment (last check the damage was approximately $2600 and growing since June).
And yes, I know the CD is pretty inexpensive, but I really prefer to get the paper version. Although I spend considerable time on my PC, I just like paper for manuals and technical publications.
When it is cold out and the weather is bad, I often retire to my electronics bench in the basement to restore vintage radios. The Holy Grail for schematics and data for these old devices is a series of manuals (Rider's Perpetual Troubleshooters) published from around 1929 to 1952. Comprising 23 volumes in all, you can get the set on CD for little cost. I have an original set (sans three volumes) that covers about 5 feet of shelf space.
Just prefer paper to bits and bytes.
I promise though, when I build up my truck war chest again, I will get a Parts Manual reprint.
J.D.
Old Nov 19, 2012 | 09:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Reprint available from Dennis Carpenter for $200.00 / CD available from hipoparts.com for $21.50.
Try faxonautolit.com (actual walk in store located in Riverside CA) for the paper version, may have a user or a reprint.
C1TT-4813-C .. Seal / Obsolete
BEN DAVIS FORD in Auburn IN has 2 = 260-925-3100.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
Old Nov 19, 2012 | 10:16 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That seal must be the same as a wheel bearing seal, check this out: Ford 60's Truck Hub Grease Retainer Part C1TT 4813 C | eBay
Can't beat the price
Old Nov 19, 2012 | 10:30 AM
NumberDummy
Wonder where the ebay seller came up with this jazz?
I just read thru 229 front hub & drum parts lists for 1964/72 trucks, it's not listed.
Front hub seals are 1175's or 1190's.
Notmeofficer
Large Truck
Aug 12, 2014 04:00 PM
1951flatheaddave
Aug 30, 2013 08:13 PM
jecsd1
Sep 6, 2008 02:23 AM
77f2504by4
Oct 16, 2007 05:36 PM
cordespc
Jun 23, 2007 04:26 PM
