Transmissions power capabilities?
Old Nov 15, 2012 | 09:15 AM
MarkG.'s Avatar
MarkG.
What kind of power will my stock trans in my 51 Ford F5 handle? Would it handle a diesel engine's power/torque? what about the rest of the drivetrain?
Old Nov 15, 2012 | 07:26 PM
38 coupe's Avatar
38 coupe
Which transmission do you have in your F-5? There were three options new: 4 speed crashbox, 4 speed synchro, 3 speed heavy duty. The 4 speed synchro is a T98 which was used behind big block V8s. The stock rear axle is probably good to go for whatever you can fit under the hood, but is probably geared really low.
Old Nov 15, 2012 | 09:04 PM
The Horvaths's Avatar
The Horvaths
Does the rear end have a two-speed differential?
Old Nov 16, 2012 | 10:46 AM
MarkG.'s Avatar
MarkG.
My F5 has a 4-speed un-synchronized trans and the rear axle is a single speed, but im not sure of its ratio, but its very low.
Old Nov 16, 2012 | 11:44 AM
4tl8ford's Avatar
4tl8ford
Your Truck was built to haul heavy loads, day in, day out - If you're going to drive it as it was intended it will handle the power/torque of the deisel engine
You won't be able to rev the engine and dump the clutch like a drag racer
Old Nov 19, 2012 | 10:44 AM
MarkG.'s Avatar
MarkG.
I believe my trans is a B-W t9, as it is a un-synchronized 4-speed trans. does anyone know if it would handle the power of a IH dt or d360 diesel? if possible id like ta keep the stock trans, but if it comes down to it, im not afraid ta replace it.
BaleJockey700
Large Truck
Mar 31, 2017 09:05 PM
Chris 56 f6
Mar 19, 2013 11:13 AM
dieselbronc
Large Truck
Aug 13, 2010 12:34 PM
kaj223
Large Truck
Apr 12, 2010 02:26 AM
bmaltb
Dec 9, 2006 09:24 AM
