Firing order
Old May 22, 2003 | 10:50 AM
dutchmen's Avatar
dutchmen
Firing order
I have 1976 F-150 - 460 engine. Stamped timing order on the intake is 15426378. Using this timing order,the truck backfires through carb.
Distributor rotation is counterclockwise and the cylinder numbering I use is 1-4 on passenger side 5-8 on drivers. I have set the order at 15437268 and it runs fine...Any ideas??
Old May 22, 2003 | 12:11 PM
Mil1ion's Avatar
Mil1ion
Firing order
There is something wonky here.
It seems like some wires are out of position on the cap.
Old May 22, 2003 | 12:25 PM
Just Strokin's Avatar
Just Strokin
Firing order
Mil1ion....Not to be cute....but he did say the firing order was on the intake manifold of his motor????
I would suggest you rotate the crankshaft around to the timing marks line up....you may need to rotate it one more turn to get the pointer to point at #1....or where #1 is actually located....then check to see if that is actually #1 plug wire. Someone in the past may have pulled the distributor out of the motor and not put it back so the pointer aligns with the #1 on the distributor cap.
Old May 22, 2003 | 12:30 PM
Mil1ion's Avatar
Mil1ion
Firing order
Thanks Larry,
It's obvious I had a brain freeze there and looked something up.
I changed my reply.
Old May 22, 2003 | 12:40 PM
jbalestri's Avatar
jbalestri
Firing order
This may be a stupid question, but I thought that cylinders were even banks and odd banks. IE Driver side was 1, 3, 5, and 7 and the passenger side was 2, 4, 6, 8.
Am I wrong on this?
I can't picture it in my head, but going 1, 2, 3, 4, 5, 6 etc around the motor doesn't make much sense either.
Nevermind, I got confused.
Old May 22, 2003 | 01:19 PM
Just Strokin
Firing order
All Fords that I have ever worked on are 1234 on passenger side and 5678 on drivers side...
chebbie/gm does the 1357 and 2468
Old May 22, 2003 | 01:27 PM
jbalestri's Avatar
jbalestri
Firing order
I know. I realized after I posted.
Can we say brain fart?
Sorry.
bbussman40
Jul 9, 2012 11:55 AM
EpicCowlick
6.7L Power Stroke Diesel
Apr 13, 2010 05:35 PM
NJF350SD
New Jersey Chapter
Dec 17, 2007 08:39 PM
E-WA
Sep 22, 2004 07:46 AM
