mechanical diode failure?
Old Nov 18, 2012 | 11:53 AM
Horseyfella's Avatar
Horseyfella
01 F350 7.3 sc 4x4 auto 36,500 miles.
15 degrees this morning, started truck and it lurched forward a little....... weird. Let it warm up, took off and it didn't want to shift into second. That symptom is intermittent. There's also a snapping sound coming from the drivetrain somewhere. Did my infamous diode fail? Do I need a rebuild at 36k? Any thoughts or ideas? Thanks in advance!
Old Nov 18, 2012 | 12:02 PM
hydro man 17's Avatar
hydro man 17
Mine failed on the origional owner at about that same mileage
Old Nov 18, 2012 | 01:15 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Your symptoms are those of a failed mechanical diode.
Old Nov 18, 2012 | 04:24 PM
Horseyfella
That's what I figured...... I just got the truck in june but I tow heavy. I knew it would go sometimes but didn't think at 36k. Anything I should consider adding during the rebuild. Torque converter, valve body, I'm looking for something hd but I don't have Bts/Jw money to spend.
Old Nov 18, 2012 | 06:21 PM
Bonanza35's Avatar
Bonanza35
Then just buy the ford HD4R100, but make sure thats the one you are getting. 3 year unlimited miles.
Chet
Old Mar 19, 2013 | 12:52 PM
Studawg's Avatar
Studawg
Thread Ender
So I read in other threads that 4600 rpm under certain circumstances causes the mechanical diode to fail. Why, then, does it matter if a 7.3 has the mechanical diode or not since it never sees 4600 rpm?
Old Mar 19, 2013 | 02:02 PM
jetdoc's Avatar
jetdoc
I dont have a AT in my truck but I've never heard of a 'mechanical diode'. I know a diode does in electronics though.
Old Mar 19, 2013 | 02:16 PM
Horseyfella
It's a one way clutch, my diode was replaced with a sprag style.
Old Mar 19, 2013 | 03:02 PM
Mark Kovalsky
That is the exact reasoning that Ford used when they pulled the mechanical diode out of the gas trucks at the start of the 2001 model year but left it in the diesels.
The truth is that at 4600 RPM it is possible to destroy the mechanical diode in one shift, if the driver knows how to do it. At lower RPM like the diesel turns it takes longer, but they get there, too.
Mechanical Diode is a brand name for a type of one way clutch.
Old Mar 19, 2013 | 03:20 PM
trekbasso's Avatar
trekbasso
So, horsey, what happened?
Old Mar 19, 2013 | 03:26 PM
Studawg's Avatar
Studawg
Thread Ender
Ahhh, gotcha. Thanks.
Old Mar 19, 2013 | 04:07 PM
Horseyfella
I brought my truck to a local reputable transmission shop where it was rebuilt with a list of improved parts and upgrades to make the tranny more HD. Billet triple disc tc, valve body improvements for better shifts and increased line pressure for less slip, better clutches, I forget the rest. It was done within a week and cost $3,150. It is disheartening when it happens, especially since I bought the Ford 7.3 for it's reliability - add in a bunch of other stuff I'd rather not have to deal with; hutch, harpoon, 50 cent mod, vc harness chafe, cps failure, od steering column wire, ect, this truck may come up for sale sooner than I expected.
Old Mar 19, 2013 | 04:23 PM
Mowing Man's Avatar
Mowing Man
Not trying to hijack a thread, but my 01 started acting up today, almost like a bad u joint, which its not. Contemplating buying an upgraded HD rebuilt, and installing it myself. How can I flush my tranny cooler before putting in the new tranny?
trekbasso's Avatar
trekbasso
Yes, I hear ya! Pretty much a love/hate relationship here, but it tows our trailer pretty well. The only reason I have it is to tow with. Hard to say if others would be better, and we do have the benefit of learning from others.
If not for FTE it would have gone buy buy a long time ago.
Old Mar 19, 2013 | 04:25 PM
Studawg's Avatar
Studawg
Thread Ender
Thats a bummer. I dont have a 01 so I dont have the diode issue, but for what its worth, I have never done any of the other things you mentioned on my 02, knock on wood, up to 150k.
